AH FabricationsChris Nott
Results 1 to 12 of 12
Like Tree5Likes
  • 1 Post By WAFTER
  • 2 Post By matts1
  • 2 Post By the_cueball
Thread: Swirl marks.
    s3clarke's Avatar
    Money grabbing s3!
    Jun 2012
    Bromsgrove
    671
    Swirl marks.
    What's best to get rid of light swirl marks in dark paint, without a buffer?
    Audi s3 goodwood green, BAM, n249 delete, 80mm TIP, s2000 air-filter, new turbo, ap coil overs, lots of poly bushes, 15mm spacers all round rolling on 18'' RSTT's
    Gizmo68's Avatar
    VCDS owner in Kent
    Nov 2012
    Folkestone, S.E. Kent
    85
    Without a machine polisher you want something like AutoGlym Super Resin Polish (SRP) as it contains ‘fillers’ which will mask the swirls, this doesn’t last forever though, the only way to fully remove them is by a machine polisher.
    VCDS HEX+CAN owner - covers all VAG cars
    (PM me if you require VCDS coding in Kent)
    MY11 Audi TT TDi
    MY11 Skoda Superb Estate
    DickosS3's Avatar
    Dec 2012
    Accrington
    30
    Quote Originally Posted by Gizmo68 View Post
    ^1
    s3clarke's Avatar
    Money grabbing s3!
    Jun 2012
    Bromsgrove
    671
    Swirl marks.
    Cheers pal.
    DickosS3's Avatar
    Dec 2012
    Accrington
    30
    Re: Swirl marks.
    Get urself a machine polisher pal. Well worth the money. Start with a da. Ull be suprised with the results.
    Gizmo68's Avatar
    VCDS owner in Kent
    Nov 2012
    85
    I have a Makita forced rotation DA if you are interested, 5 pads, 3 backing plates etc used on a handful of cars, looking for £160, Advert is here:
    Classifieds: Makita BO6040 machine polisher, little use
    MY11 Audi TT TDi
    Aug 2011
    277
    Removing swirls with a machine polisher takes practice to achieve the skills required. Why bother when a professional will do it for you. Having peace of mind and somebody else doing the work and having the responsibility is worth the few bob spent.
    Followed up with a good hard protective finish will minimise repeating the process too often.
    s3clarke likes this.
    Mar 2009
    38
    as said, will be difficult without a machine polisher. I tend to use Poors boys Black hole glaze as it is designed for darker cars and is really easy to use, followed up with nattys past wax, again, easy to use and designed for darker colour cars. I found these also didn't show up stone chips like some polishes.
    s3clarke and Gourlay1990 like this.
    Oct 2012
    East Kilbride
    343
    There are some polishes out now that work well by hand to remove light swirls... Gtechniq P1 for example...
    It may be a bit harder because Audi paint is 'generally' considered hard, but worth a shot...
    :thumb:
    sidibear's Avatar
    Looking for Zombies !!
    Nov 2008
    Birmingham UK
    1,993
    +1 here for Poorboys blackhole, finished mine off with collinite to seal it. Still looking good after 2 months of being kept outside.
    JSD 2.59
    Synergy-Solutions
    s3clarke's Avatar
    Money grabbing s3!
    Jun 2012
    Bromsgrove
    671
    Thanks guys, the poor boys is defiantly on the cards after xmas. had my eyes on it before. I used auto glym SRP then dodo juice purple haze on it the other day. the shine is lovely, but there is a few swirls in the paint. I'm probably being a bit over the top, but would like the paintwork as good as I can get it, then if i'm still not happy my pal machine polishes cars pretty cheap.
    sidibear's Avatar
    Nov 2008
    Birmingham UK
    1,993
    The only problem is that when you do start and get rid of the swirl marks you tend to get really anal about the finish as any swirls you have missed will stand out more, and drive you nuts until you sort them. It will totally transform the finish of your car though.
    JSD 2.59
    Synergy-Solutions
  1. Swirl marks after moppingfrom paint shop
    By chrisru in forum Detailing
    Last Post: 9th October 2010, 04:16
  2. how to avoid swirl marks
    By chris1988brown in forum Detailing
    Last Post: 10th March 2010, 13:36
  3. Swirl Mark Removal??
    By bl_1969 in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st March 2009, 19:39
  4. hand swirl mark removal
    By Rob_k in forum Detailing
    Last Post: 7th August 2007, 00:58
  5. Replies: 3
    Last Post: 10th March 2004, 19:49
