EM TuningBadger5
Results 1 to 24 of 24
    Dubbers1's Avatar
    Top Gear
    Jul 2011
    Bedfordshire
    220
    First attempt at Wet Sanding
    First of all I am far from a pro at this and I would recommend having a Paint Depth Gauge before attempting this
    So heres the orange peel I had on my front arches
    First I took paint depth measurements, then started off with 1200 grit then 2000 grit and finishing off with 3000 grit
    Once I was happy most of the peel was gone I polished it back up with my DA
    Once I was happy the gloss had all been restored I sealed the paint and whacked some water on it for an arty shot
    Obviously far from perfect as it was my first go ever but I am more than pleased with it, makes such a difference just looking at the car
    Comments welcome
    Audi A4 1.8T S-Line Quattro (190) '04
    VCDS HEX-USB+CAN
    scotty76's Avatar
    Nov 2011
    Berkshire
    1,062
    Nice work. What polish did you use with the DA to bring the gloss back?
    Dubbers1's Avatar
    Top Gear
    Jul 2011
    Bedfordshire
    220
    Thanks, I tried quite a few but I think i ended up with Meguiars 105 on a wool pad and then some Menzerna PO85RE to refine
    Threw in some 3M Fast-Cut Plus at some point too
    Would of been a whole lot easier with a Rotary but I've not stepped up to the big leagues yet
    VCDS HEX-USB+CAN
    Greeny233's Avatar
    Mar 2011
    Leuchars
    648
    Follow Greeny233 On Twitter Add Greeny233 on Facebook Add Greeny233 on Google+ Visit Greeny233's Youtube Channel Visit Greeny233's Instagram Channel
    Very very brave! Well worth it though, looks so much better.
    Chris "the machine" Green.
    2004 Audi A4 1.9tdi Sport Quattro Avant
    Aug 2012
    Cotswolds
    57
    Nice work, looks much better.
    Simon
    Acheron's Avatar
    Jan 2012
    South Africa
    263
    Nicely done! Very brave indeed. I still get scared everytime I use my DA...wetsanding would just push me over the edge
    Current: 2010 Audi S3 Sportback S-tronic
    Ex: 2007 Audi A3 Sportback - 2.0T DSG
    Ex: 2008 Opel Corsa OPC
    Ex: 2004 Opel Corsa Lite
    Ex: 1978 VW Beetle
    Dubbers1's Avatar
    Top Gear
    Jul 2011
    Bedfordshire
    220
    Thanks guys, was a bit of a squeaky bum exercise but now I've done it it wasnt all that bad
    Very time consuming but I was taking paint measurements and wiping it down every 2 seconds to make sure I didnt go too far
    VCDS HEX-USB+CAN
    Jul 2012
    Great results, just bought some 2500 grade sand paper for our s4 as well. Where did you paint depth gauge from?
    Dubbers1's Avatar
    Top Gear
    Jul 2011
    Bedfordshire
    220
    Quote Originally Posted by DeanG View Post
    Where did I get it from or where did I measure?
    If you're using 2500 grit I hope you have a Rotary because it took a long time getting the gloss back from 3000 grit with my DA, could have just been me though
    VCDS HEX-USB+CAN
    willowsdad's Avatar
    Sideways
    Oct 2011
    Medway-Kent
    1,022
    Nice work mate. Had that wing been resprayed? Normally only see orange peel like that on bmw's! Cracking results though.
    A3 3.2 Quattro Sport
    Dubbers1's Avatar
    Top Gear
    Jul 2011
    Bedfordshire
    220
    Yer I think both of them have seen paint, must have been an all round crap job though cos I think they both have rust bubling up from the wheel well
    VCDS HEX-USB+CAN
    scotty76's Avatar
    Nov 2011
    Berkshire
    1,062
    Quote Originally Posted by Dubbers1 View Post
    ... I hope you have a Rotary because it took a long time getting the gloss back from 3000 grit with my DA, could have just been me though
    That's why I asked what polish you'd used. I always assumed it would be impossible to get sanding marks out with a DA on Audi paint. Very nice work. I wouldn't have the bottle for it!
    Dubbers1's Avatar
    Top Gear
    Jul 2011
    Bedfordshire
    220
    Just go for it mate, results speak for themselves, just go careful near the lines and edges, use lots of water and clay lube (I also added some ONR)
    Worst comes to worst and you cant get the marks out, someone will be able to, for a few bob
    VCDS HEX-USB+CAN
    Oct 2012
    Wigan
    178
    Quote Originally Posted by scotty76 View Post
    no iy is no impossible with a DA as long as you work up to 2500 or 3000 wet sand you will be ok, I use a varaity of Menzerna cut and various polishes and top it of with Zano z3
    Jul 2012
    I'll be using my rotary with 3m fast cut and then go onto using their finer compounds. Any recommendations on measuring the thickness of paint?
    Oct 2012
    Wigan
    178
    you need a paint depth gauge fella not cheap as well, this is one of the cheap versions
    Dubbers1's Avatar
    Top Gear
    Jul 2011
    Bedfordshire
    220
    I have this one
    Paint Detective PD8 - Professional Paint Depth Gauge - Elite Car Care
    You get a discount if you are a Detailing World member, but still expensive
    There are cheaper versions out there though
    VCDS HEX-USB+CAN
    666markyboy's Avatar
    Mar 2008
    Oldham, Manchester
    1,105
    Does a paint guage not just tell you the thickness down to metal ??? whats to stop you cutting into the base coat or worse still the primer ??? or can they measure individual paint coats ??
    1999 A3 Quattro 1.8T Pics >>HERE
    2002 A4 Avant quattro 1.9 TDi
    Dubbers1's Avatar
    Top Gear
    Jul 2011
    Bedfordshire
    220
    You are right, the ones like mine only measure to the metal but you can get ones that measure each coat and they are MEGA money
    The sort of rule of thumb is that you measure the exterior paint surface then take a measurement from inside the door shut or engine bay and subtract it, therefore you have a rough guide of how much clearcoat that you can remove safely as doorshuts receive less clear coat than the exterior
    Obviously this is not a sure fire method especially with resprayed panels, just a rough limit than you can try to stay above
    VCDS HEX-USB+CAN
    Mar 2008
    Oldham, Manchester
    1,105
    I guess if it's only orange peel your doing then as long as you don't go much lower than the lowest points of the peel effect then you should be fine... if that makes sense lol
    Juicy Jen's Avatar
    Jen – Juicy Detailing
    Jun 2011
    County Durham
    835
    The other thing to point out is if the panels have been resprayed the thickness is more than OE paint so you do have more to play with.....do you have any closer pictures like the original ones to show that the sanding marks are gone? Glossing up the paint and fully removing the sanding marks are two different things tbh.
    Just concerned others jumping at this and thinking its easy
    Authorised Sponsor of Audi-Sport.net with exclusive offers for members
    2012 8P3 AKA The Green Goblin in Exclusive Java Green, Stage 1 Shark bite
    Banned
    Apr 2009
    Coventry
    2,212
    Wouldnt have to go through all this if audi didnt have shyyte paint.Mine looks like a fecking greengrocers window!
    Banned
    Apr 2009
    Coventry
    2,212
    Quote Originally Posted by Juicy Jen View Post
    Quite.Need proper lights to show everything up I guess.I hate my paintwork as its very peely, but im dangerous with a da let alone a sander!
    Juicy Jen's Avatar
    Jun 2011
    County Durham
    835
    I know what you mean I've wet sanded the front driver wing on mine and I personally think it looks the best bit on the car now lol...its just having the time to do it all!
  1. Wet Sanding
    By carlover in forum General Technical / How To
    Last Post: 7th October 2008, 17:00
  2. Recommended polish to use after wet sanding?
    By sherry in forum Detailing
    Last Post: 20th May 2008, 19:56
  3. First attempt at detailing
    By col6821 in forum Detailing
    Last Post: 9th January 2008, 10:02
  4. First attempt on my A3
    By Craigybaby37_A3quattro in forum Detailing
    Last Post: 4th January 2008, 20:40
  5. Polished Bliss: Wet Sanding & 8 Hours machining....
    By Clark@Polishedbliss in forum Detailing
    Last Post: 25th September 2007, 18:39
