Chris NottSky Insurance
Results 1 to 13 of 13
Like Tree6Likes
  • 2 Post By butler2.8i
  • 1 Post By Craig Edis
  • 1 Post By R90 STL
  • 1 Post By Brodster
Thread: Audi A3 Enhancement Detail Plus Wheel Powder Coating
    Jun 2009
    Hartlepool
    183
    An enhancement detail on a kitted Audi A3 TDI which the owner had just bought the owner also wanted the alloys powder coating in gun metal grey and also the brake calipers painted silver. Not my usual amount of photos as i seem to have lost some when laptop died, but anyway on with the write up.
    Products and equipment used
    Uber microfiber towels
    Chemical guy’s woolly mammoth drying towel
    3m yellow pads 150mm 75 mm
    3m black pads
    Halogen site lights
    Makita rotary polisher
    DA Polisher
    Carpro Fixer polish
    Carpro eraser
    Britemax Black Max
    Britemax Vantage wax
    3m masking tape
    Meguiars APC
    Costco microfibre towels
    Meguiars hyper dressing
    Valet pro citrus bling
    Valet Pro PH neutral Snowfoam
    Valet pro bilberry wheel cleaner
    Valet pro tyre dressing
    AMDetails AMbubbles
    Bilt Hamber clay bar
    Autosmart Tardis
    Various brushes
    Kranzle pressure washer
    Carpro Sheepskin wash mitt
    Carpro Dlux
    Noodle wash mitt
    Carpro Lambs wool wash mitt
    Poorboys microfibre clothes
    Uber buffing clothes
    Autobrite Snow foam gun
    Chemical guys Jetseal 109
    Autobrite Repel
    The car was then given its first coat of snow foam whilst this was dwelling I went round the car using APC in a foaming head bottle cleaning the fuel filler area and various gaps and grills. The snowfoam was then blasted off with the pressure washer, and then the car was given another coat of the same mix snowfoam and the car was washed using the 2 bucket method with grit guards in both buckets and a Carpro lambswool wash mitt.
    The car was then rinsed off using an open ended hose and I then went round the car with Tardis which was left to go to work before being wiped down with microfibre clothes. The car was then given a coat of Ironx again left to do its stuff before the car was washed down using the pressure washer.
    The car was clayed using citrus bling and water mix (10 to 1) and a Bilt hamber soft clay bar which helped to pull more contaminates from the paint work it was then rewashed using the same method and dried using the woolly mammoth.
    The car was then taken into unit to have the wheels removed ready to be dropped off at the powder coaters the next morning so once the car was on he axle stands I started on the arches next and they where sprayed with APC and cleaned using various brushes and a noodle wash mitt. They where then sprayed with Tardis which was left do its stuff whilst I moved onto the next arch before going back and being wiped down with a microfibre cloth and left to dry. And then before the wheels were refitted after the powder coating they were given a couple of coats of Megs Hyper dressing.
    The brakes where given 2 coats of silver hammerite smooth finish paint using various brushes
    Some shots of the car before showing dealer prep
    I then taped the car up and went round with various yellow 3m pads and Carpro Fixer polish, each panel was given a wipe down with Carpro eraser after polishing to check finish and remove any polishing oils.
    I then went round the car a using the DA and Britemax blackmax on a black 3m pad which was buffed using Uber buffing towels.
    Jun 2009
    Hartlepool
    183
    The car was given 2 coats of the Britemax Vantage wax leaving wax to bond for 30min and approx 60min between each coat again buffed using Uber buffing towels
    The plastic trim was dressed using Carpro Dlux which is a cracking product which a little goes a long way and gives a stunning finish.
    After this I cleaned the glass and gave them all 2 coats of Autobrite repel
    Before the alloys were refitted the were sealed using 2 coats of Chemical guys Jetseal 109 and the calipers were also given 2 coats and dressed the tyres using the Valet pro tyre dressing.
    Finished shots
    Here’s a link to my facebook page
    http://www.facebook.com/NorthEastCarCareUK
    Juicy Jen and Craig Edis like this.
    Craig Edis's Avatar
    Aug 2012
    Cleveland
    Nice Work, Bet The Owner Is Well Chuffed!
    AUDI_ADDICT likes this.
    shafs3's Avatar
    Sep 2012
    Leeds
    30
    Nice!! How much would this cost? And where are you based?
    Juicy Jen's Avatar
    Jen – Juicy Detailing
    Jun 2011
    County Durham
    835
    Stunning work as always Shaun...typical dealer prep!
    Authorised Sponsor of Audi-Sport.net with exclusive offers for members
    2012 8P3 AKA The Green Goblin in Exclusive Java Green, Stage 1 Shark bite
    warren_S3's Avatar
    Oct 2007
    6,133
    Great job; nothing like a good clean to restore the love for your motor. Fantastic restoration job.
    Once it's lowered it will look a treat!
    Mar 2012
    Cumbernauld
    628
    Outstanding job.
    Jun 2009
    Hartlepool
    183
    Quote Originally Posted by Craig Edis View Post
    Cheers Craig
    Jun 2009
    Hartlepool
    183
    Quote Originally Posted by shafs3 View Post
    I`m based in Hartlepool and price depends on condition of the car and to what level the owner wants to take it to really.
    I try to tailor my detailing packages to suit all budgets
    Craig Edis's Avatar
    Aug 2012
    Cleveland
    Lowerd!! Mmmmmmmm
    butler2.8i likes this.
    R90 STL's Avatar
    Apr 2013
    Glasgow
    509
    Follow R90 STL On Twitter Add R90 STL on Facebook Visit R90 STL's Instagram Channel
    great job!!
    Brodster's Avatar
    Shark Performance In Scotland
    Mar 2011
    Scottish Borders
    3,217
    Follow Brodster On Twitter Add Brodster on Facebook
    I like the Brooklands 280 Capri in the background............very rare to see one of those nowadays.
    Angelwax/BBS/BCS/Bilstein/Cobra/CTS Turbo/H&R/K-Sport/KW/Loba/Milltek/Shark Performance/Oz Racing/VCDS/Wagner
    Jun 2009
    Hartlepool
    183
    Quote Originally Posted by Brodster View Post
    Cheers matey, owner also has his tickford Capri stored there at the moment
  1. R32 Enhancement Detail Plus Wheel Powder Coating
    By butler2.8i in forum Detailing
    Last Post: 20th September 2012, 20:21
  2. Audi TTS - Enhancement Detail + Swissvax
    By Proshine in forum Detailing
    Last Post: 1st May 2011, 10:55
  3. 8P3 S3 Standard Wheels - Powder coated Black?
    By taylorc in forum A3/S3/Sportback (8P Chassis)
    Last Post: 4th February 2011, 22:52
  4. Is it best to have wheels powder coated or sand blasted and sprayed?
    By jack.s in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th January 2011, 14:49
  5. wheels Powder Coated, milltech cat back exhaust, forge dv and tints
    By ALP A3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th August 2009, 17:56
Tags for this Thread
