butler2.8i
Jaguar XF Enhancement Detail
Products and equipment used
Uber microfiber towels
Chemical guyâs woolly mammoth drying towel
3m yellow pads 150mm 75 mm
140 mm Glazing pads
Halogen site lights
Makita rotary polisher
DA Polisher
Scholl s17+
Blackfire all finish paint protection
Blackfire Midnight sun paste wax
Werkstat prime acrylic
Carpro eraser
3m masking tape
Meguiars APC
Costco microfibre towels
Meguiars hyper dressing
Valet pro citrus bling
Bilt Hamber AutoWheels
Valet Pro PH neutral Snowfoam
Valet pro tyre dressing
AMDetails AMbubbles
Bilt Hamber clay bar
Autosmart Tardis
Various brushes
Kranzle pressure washer
Carpro Sheepskin wash mitt
Carpro Dlux
Noodle wash mitt
Carpro Lambs wool wash mitt
Poorboys microfibre clothes
Uber buffing clothes
Autobrite Snow foam gun
Chemical guys Jetseal 109
Autobrite Repel
Auto Finesse Mecury Metal Polish
00 grade wire wool
Some photos of the car before I start
The car was then given its first coat of snow foam whilst this was dwelling I went round the car using APC in a foaming head bottle cleaning the fuel filler area and various gaps and grills. The snowfoam was then blasted off with the pressure washer, and then the car was given another coat of the same mix snowfoam and the car was washed using the 2 bucket method with grit guards in both buckets and a Carpro lambswool wash mitt.
The car was then rinsed off using an open ended hose and I then went round the car with Tardis which was left to go to work before being wiped down with microfibre clothes. The car was then given a coat of Ironx again left to do its stuff before the car was washed doing using the pressure washer.
The car was clayed using citrus bling and water mix (10 to 1) and a Bilt hamber soft clay bar which helped to pull more contaminates from the paint work it was then rewashed using the same method and dried using the woolly mammoth.
The arches where next and they where sprayed with APC and cleaned using various brushes and a noodle wash mitt. They where then sprayed with Tardis which was left do its stuff whilst I moved onto the next arch before going back and being wiped down with a microfibre cloth.
A few shots using my site lights I then taped the car up and went round with various yellow 3m pads and Scholl s17+ polish each panel was given a wipe down with carpro eraser after polishing to check finish and remove any polishing oils.
140 mm Glazing pads
Halogen site lights
DA Polisher
Scholl s17+
Carpro eraser
3m masking tape
Meguiars APC
AMDetails AMbubbles
Autosmart Tardis
Various brushes
Carpro Dlux
Noodle wash mitt
Autobrite Repel
00 grade wire wool
