EM TuningMonster Motorsport
Results 1 to 8 of 8
    Juicy Jen's Avatar
    Jen – Juicy Detailing
    Jun 2011
    County Durham
    835
    Juicy Detailing Candy White Seat Leon FR
    Stuart recently purchased a Candy White Seat Leon FR 59 plate which is a typical example of a vehicle that has been washed using either automatic car washes or the cheap roadside services (yeah you know the ones I mean!). As he uses his car as a daily ride and time was limited Stuart was looking to enhance the look of the paintwork but aware that within the space of a day it would be quite difficult to achieve 90 to 95% correction of the paintwork.
    Another slight difference to what we usually do is that Stuart wanted to help with the Enhancement and learn how to machine polish. Therefore prior to me working on the car he did the following:
    Pre-wash using Juicy Snow foam; Rinsed; Washed using the 2 bucket wash method, a Dodo Juice Tribble Mitt lambswool wash mitt and Chemical Guys Maxi Suds Shampoo; Rinsed; Decontamined using Car Pro Trix which is a combination of iron fall out and tar removal and then clayed using yellow fine poly clay and Valet Pro Citrus Bling as lube.
    Rinsed and washed again using the above method and then finally dried using Supernatural Microfibre Drying Towel.
    The car was taken inside our new detailing bay and paintwork evaluated and depths taken. Now generally white is quite a hard colour to see imperfections on however due to the state of this is was quite easy, again just a couple of photos as virtually the whole car was the same.
    Nice of example of marring from the clay due to poor use of clay lube and rushing....ok I'll let him off as it was he was a "virgin clayer"....
    Next stage after the evaluation was to tape up all the edges using Scotch High Performance Masking Tape. This is to protect the panel edges as the paint depth is thinner in these area and trims from being marked by polish. This picture is quite a good example of how paintwork can look shiny but up close have a vast amount of imperfections...so hence the importance of the lights we use.
    As per usual a few test sections were done and boy was this paint rock hard as you expect from the VAG cars, ie. the likes of Seat, VW, BMW and Audi generally always have hard paint therefore you need to have a slightly more aggressive combination of polish and pads....The weapon of choice was my Festool Rotary and we settled on using Scholl S17+ polish and a Scholl white/black spider polishing pad
    A keen young detailer popped in to see how we were doing and help his dad out
    50/50 shot of the bonnet (right side corrected)
    Ok so its not perfect, but we are not looking to correct all imperfections due to the time limitations we have available. Only the deeper scratches remain
    Bonnet corrected and you can see the difference in that the reflection rather than just shiny has colour as the majority of imperfections have gone. Clarity has been restored - Stuart went over with a Kestrel DAS6 Polisher using a Black Hex Logic Finishing Pad and 3M Ultrafina finishing polish
    So starting to move around the car...this just shows the difference from bonnet to side wing
    Passenger side (right corrected)
    Nearly there - this was around 1 in the morning
    All the correction has been completed, tape removed and wiped down to remove any remaining oils and fillers. We decided to call it a night and come back in early Sunday morning to apply the final products.
    A coat of Chemical Guys Wet Mirror Finish Gloss Magnifier using a Juicy foam applicator and finally a coat of Chemical Guys Lava Paste Wax Luminous Glow Infusion was applied.
    Wheels and trims dressed using Valet Pro Dionysus Trim Glitz and windows cleaned using Chemical Guys Glassworkz Glass Clean
    Mmmmm who says you can't get white looking dripping wet
    We took the car outside to take a complete look
    Thanks for looking
    Authorised Sponsor of Audi-Sport.net with exclusive offers for members
    2012 8P3 AKA The Green Goblin in Exclusive Java Green, Stage 1 Shark bite
    Jul 2012
    Newport, South Wales
    26
    Very nice job done there! Also I need some of the tar and iron x how do I go about ordering some??
    Mar 2012
    Cumbernauld
    666
    Quality job
    BigWillyStyle's Avatar
    Aug 2012
    566
    Looks awesome, when i was looking to buy a car a few weeks back it was between and FR or an S-Line, obviously S-Line won but still love the FR's
    Juicy Jen's Avatar
    Jun 2011
    County Durham
    835
    Quote Originally Posted by Ashley M View Post
    We've only got the 1 litre left, if you click on the Car Pro Trix its linked to the product on our website
    _G_
    _G_'s Avatar
    Jul 2011
    869
    mad props to JJ
    whale's Avatar
    Jul 2012
    Auckland, New Zealand
    55
    Damn! I need that done! Looks fantastic!!
    DALE_AVANT's Avatar
    Avantage
    Jan 2012
    442
    Looks pretty crisp!
    White with black looks ace
    *WANTED* AUDI CD PLAYER
  1. Seat Leon Enhancement Detail
    By butler2.8i in forum Detailing
    Last Post: 25th June 2012, 20:31
  2. Anyone fitted a SEAT Leon Cupra R Lower Strut Brace?
    By Markb in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th September 2005, 12:44
  3. New Seat Leon Prototype revealed!!
    By deebo in forum Other Brands & Models
    Last Post: 2nd September 2005, 00:31
  4. seat leon cupra r... brembo brakes
    By jediknight in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th May 2005, 22:13
  5. New Seat Leon Prototype
    By neversaydie in forum General Chat
    Last Post: 25th April 2005, 21:24
