EM TuningAH Fabrications
Results 1 to 9 of 9
    Apr 2012
    202
    Worth getting a machine for just paint cleansing?
    I have been looking at getting a dual action machine for probably the sole task of applying paint cleansers and glazes. My car only has some light defects mainly swirls due to I think the previous owners was technique as I have always used the two bucket method.
    From having a look at another post on here it seems hexlogic white and possibly black pads would be the way to go.
    Would also anyone advise the use of a paint depth gauge? Also if I wanted to achieve more correction what polish would people advise for Audi paintwork?
    The last thing is someone convince me having the machine and using maybe 2-3 times a year is a justifiable cost?
    cloughy's Avatar
    Sep 2011
    Berkshire
    515
    Bottom line is you need a DA polisher, I've got a DAS-6 and I would not have been able to get the finish on mine without it!
    It also makes the application of my CG blacklight a breeze
    My A3 Detail - Light Silver Met
    This was my write up of my correction detail. I had to use quite an aggressive combo due to the hard paint. Didn't use a gauge as I couldn't justify buying one but if you had one to hand then use it
    Apr 2012
    202
    Did you have bad swirls and scratches or just minor swirls from washing? I don't think I need anything too aggressive on mine as the major swirls are only in on small area which I will tackle by hand.
    cloughy's Avatar
    Sep 2011
    Berkshire
    515
    I had quite bad swirls which were impossible to remove by hand, I did a test patch to remove the swirls and repeated that technique over the whole car
    due to vag paint being very hard I'm afraid going by hand won't do the job, you could use poorboys black hole to fill the swirls if you didn't want to use a DA
    willowsdad's Avatar
    Sideways
    Oct 2011
    Medway-Kent
    1,022
    You'll end up using it more than you think anyway. I use mine probably every 4-6 weeks. I started off just for mild correction, but I use it for cleaning, polishing, glazing, sealing, and I've just got a kit for polishing my glass and headlights. It just makes everything easier, but it still takes time.
    A3 3.2 Quattro Sport
    Apr 2012
    202
    Quote Originally Posted by willowsdad View Post
    Have you got DA or a rotary? I can see me end up using it for paint cleansers and glazes minimum.
    Danman1's Avatar
    Thorough noob
    Sep 2011
    West Midlands
    338
    willowsdad's Avatar
    Sideways
    Oct 2011
    Medway-Kent
    1,022
    Quote Originally Posted by Ian-83 View Post
    Ive got a das-6 DA. Might get a rotary eventually, but for what I need now it's perfect.
    scotty76's Avatar
    Nov 2011
    Berkshire
    1,077
    +1 for the DAS 6 DA. It really does lift the game compared to by hand.
  1. supaguard worth getting for 300
    By Duncan in forum A3/S3/Sportback (8P Chassis)
    Last Post: 16th February 2009, 11:00
  2. Downpipe, worth getting new flex joint welded in?
    By imported_Yaseen in forum A4/S4 forum(B5 Chassis)
    Last Post: 12th January 2005, 09:21
  3. Replies: 2
    Last Post: 15th December 2004, 20:16
  4. Can you get tuning boxes for SAME tractors??
    By smanning in forum Diesel forum
    Last Post: 17th July 2003, 09:55
  5. Want to get an A4 for around 30G's? Help?
    By b_schulz in forum A4/S4 forum(B5 Chassis)
    Last Post: 12th June 2003, 11:37
