EM TuningBadger5
Results 1 to 8 of 8
    Jun 2009
    Hartlepool
    183
    Audi TT Soft top enhancement detail
    An enhancement detail on a Audi TT which needed freshing up as the paint had lots of swirls which where stopping any real reflections to the paint work. The dirt build up and mold on the roof was also spoiling the look of this stunning car
    The roof before cleaning
    Cleaning process, The roof was cleaned using the 303 cleaner which I had to do 3 times as the amount of muck and mold on the roof was unreal
    The car was then given its first coat of snow foam whilst this was dwelling I went round the car using APC in a foaming head bottle cleaning the fuel filler area and various gaps and grills. The snowfoam was then blasted off with the pressure washer, and then the car was given another coat of the same mix snowfoam and then cleaned off again at this point it started to rain so the car was brought into the unit.
    The car was washed using the 2 bucket method with grit guards in both buckets and a Carpro lambswool wash mitt.
    The car was then rinsed off using an open ended hose and I then went round the car with Tardis which was left to go to work before being wiped down with microfibre clothes. The car was then given a coat of Ironx again left to do its stuff before the car was washed doing using the pressure washer.
    Bleeding Audi
    The car was clayed using citrus bling and water mix (10 to 1) and a Bilt hamber soft clay bar which helped to pull more contaminates from the paint work it was then rewashed using the same method and dried using the woolly mammoth.
    The owner had just had the wheels powder coated before driving it here for the work so they were cleaned using APC and rinsed.
    The arches where next and they where sprayed with APC and cleaned using various brushes and a noodle wash mitt. They where then sprayed with Tardis which was left do its stuff whilst I moved onto the next arch before going back and being wiped down with a microfibre cloth.
    The car was then brought inside for taping up and paint thickness readings to be taking and some photos of the defects on the car.
    The car was polished using Carpro Fixer polish with yellow 3m pads and my Makita rotary polisher
    50/50 shots
    Jun 2009
    Hartlepool
    183
    Started working my way round the car
    Jun 2009
    Hartlepool
    183
    After polishing I went round the car with Carpro Eraser to remove any remaining polishing oils or fillers, I then went round the car again with Britemax Blackmax and a black 3m pad using a DA polisher
    After the polishing was out the way the car was taken outside for a rinse down before being dried and the roof given its first coat of 303 high tech fabric guard also at this point the arches where dressed using Meguiars hyper dressing the alloys sealed using 2 coats of Jetseal 109 and the tyres dressed with Valet Pro tyre dressing. The next day the car was given its second coat of 303 high tech fabric guard and whilst this was drying the interior was given a hoover out and the leather seats cleaned and sealed using Furniture Clinic products. The exhausts where cleaned using Autofinesse metal polish and 00 grade wire wool.
    The car was then given 2 coats of Chemical Guys Celeste Dettaglio paste wax which was applied thin coats and buffed after 30 min leaving 60mins between coats.
    Leaving me with this
    The plastic trim was dressed using Carpro Dlux which is a cracking product which a little goes a long way and gives a stunning finish.
    After this I cleaned the glass and gave them all 2 coats of Autobrite repel and also gave the arches another coat of hyper dressing
    The car was taken outside for a couple of shots
    A couple of beading shots
    And a couple of my favourites lol
    Here`s a link to my facebook page
    http://www.facebook.com/#!/NorthEastCarCareUK?notif_t=page_new_likes
    Danman1's Avatar
    Thorough noob
    Sep 2011
    West Midlands
    338
    Excellent stuff.
    Feb 2008
    2,817
    Great work.
    2000 AMK S3, Revo'd, forge 007p, B8's, H&R's, tarox g88's, ferrodo ds2500's, and in the fastest colour
    Jun 2009
    Hartlepool
    183
    Cheers Guys
    Juicy Jen's Avatar
    Jen – Juicy Detailing
    Jun 2011
    County Durham
    835
    Whats your thoughts on Fixer Shaun? I've used it for a couple of areas on the 1M and was quite impressed for a one step type polish
    Authorised Sponsor of Audi-Sport.net with exclusive offers for members
    2012 8P3 AKA The Green Goblin in Exclusive Java Green, Stage 1 Shark bite
    Jun 2009
    Hartlepool
    183
    Quote Originally Posted by Juicy Jen View Post
    Really loving it Jen, gives a cracking finish
  1. BMW645 enhancement detail
    By butler2.8i in forum Detailing
    Last Post: 17th May 2012, 15:55
  2. Replies: 10
    Last Post: 25th January 2012, 20:02
  3. Audi TT enhancement detail
    Last Post: 20th July 2011, 17:34
  4. Audi TTS - Enhancement Detail + Swissvax
    By Proshine in forum Detailing
    Last Post: 1st May 2011, 10:55
  5. HI from the VW man looking for an Audi Soft-top
    By Ricey155 in forum The Welcome Section
    Last Post: 16th July 2009, 13:04
