Results 1 to 11 of 11
Thread: Snow foam
    Audi Novice
    Mar 2009
    Suffolk
    381
    Snow foam
    I've been thinking about getting snow foam for a while, and had the offer from a mate to borrow his to see if I liked it. A sort of try before you buy.
    anyway not that impressed, but don't know if there was a problem with the foam or the lance but it didn't come out very foamy, it was just like the shampoo that comes out of the local jet wash, just watery white stuff.
    It was maguairs snow foam and a Karcher lance, and I was playing with the + and - tap to try and get it to foam, but no luck!!
    Any ideas what the problem could be? Is this a common problem?
    Audi Northampton, Audi Ipswich, and Audi UK are rubbish and lack the basic skills of customer service.
    Please read my posts about my experience, and I hope this helps you to make the decision not to buy an Audi 2.0 TDi 170 engine, they are not fit for purpose and the tolerance levels are a joke.
    warren_S5's Avatar
    Oct 2007
    7,158
    That sounds nothing like what comes out of mine. It's almost like shaving foam as it settles on the car. Very thick and clingy and pulls dirt away from car. Made quick car washes so much easier, and much less abrasive.
    Audi S5 3.0V6T Coupe Black Edition
    nally's Avatar
    MPG the new BPH
    May 2010
    Liverpool
    2,102
    heres how it should look
    69nally's Channel - YouTube
    2009 (58) plate audi A3 Sline 2.0TDI, DRL's with washers, Half Leather / Alcantara, I Pod Aux, 15% tints / EM tuning L.E.D. interior upgrade, fully machine corrected!
    willowsdad's Avatar
    Sideways
    Oct 2011
    Medway-Kent
    1,022
    I was like that on my first try, then I found that you could adjust the nozzle aswell as the + and - knob. After a couple of goes I think I've mastered it, and it works well too. I tried it on my works transit and all the black motorway grime just jet washed straight off afterwards. Give it another try before you give it back.
    A3 3.2 Quattro Sport
    nally's Avatar
    MPG the new BPH
    May 2010
    Liverpool
    2,102
    sorry to thread jack but didnt wann start a new one
    i have used valet pro snow foam for a while now and 1ltr has last a long time and i am am pretty please with it but.
    i cant help but think i can get somthing better, like uk valet cherry snow foam what your thoughts. dont wanna pay through the nose
    Juicy Jen's Avatar
    Jen – Juicy Detailing
    Jun 2011
    County Durham
    835
    It can take a while to set up your lance to work in tandem with your pressure washer and it will not always be right from the start. When I send lances out I try and set them up how I have mine, however this may need adjustment as it can depend on make of pressure washer, pressure and the foam being used.
    So far I have found valet pro ph neutral the best as it is extra thick and sticks to the car for a long time
    The other reason it was not thick could be that the mixture was not shaken before starting the water....ie add 1 to 2 inches of foam, fill the bottle with water (hot or cold doesn't really make that much difference as the water coming through will be cold anyway). Attach the top part and shake the bottle to mix the mixture.
    I also find sometimes temperature dependant that you might need to give it a shake while the pressure washer is going to get it started. You'll get the hang of it after a while.
    There is a video of me snow foaming on the front page of the Juicy site
    Authorised Sponsor of Audi-Sport.net with exclusive offers for members
    2012 8P3 AKA The Green Goblin in Exclusive Java Green, Stage 1 Shark bite
    Helifella's Avatar
    Flying low level
    Nov 2011
    Knaresborough
    361
    Follow Helifella On Twitter
    My lance arrived this morning so I think the Juicy forecast for Knaresborough this weekend is Snow.
    Thanks Jen.
    RegardsHeliFellaVCDS newbie.8V now ordered...I.A.M. Member http://www.iam.org.uk/about-us/ '61 spec, A3 Sportback S-Line Black Edition in Ibis White, EM Tuning upgraded LED extended interior XL lightpack,Duxback Glass Treatment, Diamond Vision front fog lights, shortened number plates, gloss black rear rings & black edition S-line wing badges. Blackvue DR550GW 2 channel in-car camera with Smart Power battery protection.
    Juicy Jen's Avatar
    Jun 2011
    County Durham
    835
    Quote Originally Posted by Helifella View Post
    Thanks Jen.
    Have fun
    Mar 2009
    470
    Had the snow out today, Megs and a snow foam-lance on a Karcher pressure washer. The combo works great, you must have a prob somewhere. Would definitely recommend getting one.
    B6 S4 4.2L V8 Cabriolet Black Manual Quad Milltek Non Res
    TDIPOWARRR
    Jul 2010
    618
    Did you put a weak dilution of snow foam in? If it's to weak it won't foam up really well.
    Syvo's Avatar
    IF IN DOUBT GO FLAT OUT
    Jan 2011
    warrington
    1,337
    depends on the foam lance you using i use the standard karsher one its a small bottle that goes on the end of the lance i have to use no diluted snow foam as the water from the karcher makes it to weak other wise.
    this is the result of mixing the snow foam with water in the bottle
    it now looks more like the video above with pure non diluted snow foam
  1. snow foam lance ?????
    By vr6gordy in forum Detailing
    Last Post: 13th January 2012, 23:25
  2. Snow foam
    By Agent_Trig in forum Detailing
    Last Post: 14th June 2011, 22:25
  3. Replies: 4
    Last Post: 15th December 2010, 14:34
  4. Snow foam....
    By Wozski in forum Detailing
    Last Post: 27th September 2010, 15:47
  5. Snow Foam
    By EnzoS4 in forum Detailing
    Last Post: 22nd February 2009, 19:38
