AH FabricationsVolks Autos
Results 1 to 18 of 18
    The Doctor's Avatar
    Jul 2009
    Planet Earth
    1,175
    Pressure washer or DA polisher?
    Hi guys,
    I have an unusual opportunity to spend a couple of hundred £s on the car & it's a choice between either a pressure washer or a DA polishing kit.
    I usually use a normal garden hose with the Gilmour Foamaster foam gun from PB as a pre-wash, then a lambswool mit & 2 bucket method to wash the car. I've been considering buying a pressure washer for some time to get a better initial clean, but haven't had the free cash available to get one. Will it make a significant benefit? I always remove any loose dirt with the foam gun & hose before starting the wash and religiously wash from roof panels downwards to minimise the chances of swirling. I tend to wash the car about once every other week (limited time due to young family). Twice a year the car is clayed, hand-polised and waxed, with additional layers of wax applied when the weather & time allows (approx every other month).
    I know that I'll probably get less use out of a DA polisher, however whilst my paintwork (all original) is in good condition it does have some light swirling (the car is now 9 yrs old). I want to be able to return it to an un-blemished finish that is only possible with a machine polisher. It will be my first machine polisher, hence why I am thinking of going the DA route.
    My preference is to spend the cash on the polisher, because I will see a greater improvement in the car from that compared to a pressure-washer, which will only help to prevent further damage being inflicted when washing the car in a very dirty state (like it is now after all the snow etc!). I was thinking of getting the DA polishing kit from Polished Bliss, but I can no longer see it on their website - is it still available?
    Thoughts & suggestions?
    Farhan's Avatar
    Feb 2011
    West London
    1,228
    Hmm, Personally i would get a pressure washer and maybe use another persons DA in the mean time to sort everything out,or have a small lesson with them then opt to buy one later.
    Just remember with the polisher you may need to invest further in polishes and pads.
    Pressure washer may be good, I personally use the small karchers and it works excellent. I bought a basic one from karcher outlet for circa 45-50 quid. That may allow you to still get a dodo juice buff daddy or das-6
    2008 A3 1.8TFSI 3 Door S Line - Lava Grey - Bose - Bluetooth - S Line Full Black Leather - Aux - Comfort Pack - Coming Home Lights - Storage Pack - Cruise Control - Ambient Interior Light - Footwell Lights - Audi IPhone 4 Cradle - Leather Armrest - BE Rear - MY09 Rear Lights - S3 Pedals - S3 Vents - BBS RS866 - Bi Xenons - Bluefin Stage 1 - K&N 57S Intake - Rev D Valve - Powerflex Dogbone Insert & Gear Box Mount
    cloughy's Avatar
    Sep 2011
    Berkshire
    515
    I'd get a das-6 with megs 105 & 205 (good for hard paint) then whatever pads you like
    as above you might be able to get both
    Nov 2011
    205
    I'd say both. I have a Nilfisk that I bought from Amazon a month or so ago for £45, leaving you plenty for a DA
    Juicy Jen's Avatar
    Jen – Juicy Detailing
    Jun 2011
    County Durham
    835
    The first option should be the pressure washer as it is very important to get the wash technique correct before moving on to paint correction, otherwise you'll spend hours correcting the paintwork to simply get ruined again relatively quickly by washing poorly. You'll then correct again in what will become a vicious circle.....bear in mind the paint can be corrected only so many times.
    There are usually good deals around on pressure washers and now foam lances and prices on DA's can be found for £79.00 (ours included) therefore if you do your homework you could quite easily achieve both, without compromising on quality.
    Authorised Sponsor of Audi-Sport.net with exclusive offers for members
    2012 8P3 AKA The Green Goblin in Exclusive Java Green, Stage 1 Shark bite
    scotty76's Avatar
    Nov 2011
    Berkshire
    804
    Another vote for pressure washer first. You'll get more use out of it than a DA. I'm in the same situation as you, young family, and have both. Pressure washer is handy for the car and a whole load of other things: cleaning patio slabs, brickwork, wooden gates to name a few things I have done with it! Also I find it's brilliant at this time of year for cleaning the wheels. Most of the grime blasts off leaving little washing to do.
    HTH.
    John @ PB's Avatar
    Sep 2010
    360
    Our Hard Paint kit is here: PB Hard Paint Polishing Kit | Machine Polishing Kit For Cars With Hard Paint it's showing our of stock as Menzerna are stopping making their pads and we're swapping the pads. It'll be back in stock very soon.
    However, I'd say a pressure washer would be a better investment: get your washing sorted (and a pressure washer will remove a lot more grime than a regular hose) and minimise marring and you'll have less need to correct the paint.
    The Doctor's Avatar
    Jul 2009
    Planet Earth
    1,175
    Hmm, interesting responses, thanks guys. Glad I posted my thoughts now.
    If I go down the pressure washer route which basically you're all advising, then what brand/model would you recommend from your experience? I've heard that the induction motor models are better than the universal motor models for reasons of durability. I'd be using it probably once every other week on average, particularly during the winter when the car gets filthy really quickly. I have a limited budget so don't go recommending all-singing all-dancing industrial models. Where do prices start for reliable induction motor pressure washers?
    nally's Avatar
    MPG the new BPH
    May 2010
    Liverpool
    2,102
    Quote Originally Posted by Juicy Jen View Post
    with jen on this one DA is a summer purchase for me but the prep is key. would never be without my foam lance now
    2009 (58) plate audi A3 Sline 2.0TDI, DRL's with washers, Half Leather / Alcantara, I Pod Aux, 15% tints / EM tuning L.E.D. interior upgrade, fully machine corrected!
    scotty76's Avatar
    Nov 2011
    Berkshire
    804
    I've got a Karcher K3.97 deluxe, it has an induction motor. The deluxe bit just means it comes with a bunch of tools in particular the T-Racer patio cleaner which I wanted as I have lots of patio slabs. It's 4 years old and has been used frequently. I suspect this model has been superceded by something as you only tend to find them in the Karcher outlet shop now.
    Before Christmas it started pulsing (Google for "karcher pulsing" and you'll see) and I feared the worst. It turned out that the gun was leaking so it was easily sorted. When I thought it was dying I was looking at the Nilfisk C110 pressure washer on Amazon as they were £45 at the time.
    I'm afraid this is one of those subjects where you'll find half the people will tell you to avoid a Karcher at all costs and equally half the people will tell you to avoid Nifisks at all costs! I've always looked after my Karcher and made sure I drain the water after every use in winter to stop it freezing up (which is what kills most pressure washers) and it's been fine.
    wez3570's Avatar
    Jan 2011
    711
    +1 for the Nilfisk C110
    I've had a few different brands and this one has been the best yet.
    I sold my Gilmour Foamaster 2 with the intention of buying a foam lance but the Nilfisk foam gun (included) works really well.
    2006 A3 3.2 DSG
    Quattro S-Line
    Phantom black pearl
    V Maxx plus coilovers
    Speedlines- anthricite
    MY11 rear lights
    MK2 TT Vents
    Various LED's
    MK2 RNSE
    LaminX on fogs
    For Sale Genuine Audi phone cradle (iPhone 4S/4)
    Jan 2012
    Hertford, UK
    108
    I'm considering the c110 as well.
    Although the c120 is pretty reasonable here: http://www.worldofpower.co.uk/nilfisk-compact-c120-3-6-120-bar-1700w-pressure-washer.html
    Having never used a compact pressure washer before - just wondering how much of an effect the mains pressure would have on it?
    Ours is low to medium.
    scotty76's Avatar
    Nov 2011
    Berkshire
    804
    The pressure washer pump will "pull" the water to some extent. I use my Karcher with a water butt and that works fine. Also it says in the manual that you can do this. Not sure if the Nilfisk is the same, this might help...
    Does a Nilfisk need a mains water feed? - Detailing World
    Basically it looks like you'll be fine as long as you get 9 litres a minute which you could test with a bucket and stopwatch.
    Steven.c's Avatar
    Auto-Motive Restored Deatail
    Sep 2011
    Shropshire - West mids
    282
    i also have a nilfisk after my karcher packing up and i wanted to try something different. The nilfisk is really good and heavy duty, i've used it on tons of cars and its as good as the first day i got it. cant fault it one bit! Great value for money.
    Metallic Ming Blue a3 1.8t sport.
    K03s, Revo stage 1, Jetex(JR) filter, Silicone TIP,N249 Bypass, Forge Split-r'seee
    Mk3 GTI Project - < Click me
    nally's Avatar
    MPG the new BPH
    May 2010
    Liverpool
    2,102
    i have a normal home sized karcher, and have a polished bliss snow foam lance
    here are the results with valet pro ph nutral snow foam
    Audi A3 sline Snow Foam - YouTube
    scotty76's Avatar
    Nov 2011
    Berkshire
    804
    Nally, your car's not even dirty in that video. Come on, own up, you were just playing!
    Alan H's Avatar
    Need a V8 or Bi-Turbo.......
    Aug 2010
    Dudley, West Midlands
    453
    With a couple of hundred quid, as long as you shop around you should be able to get a PW and a DA. Karcher Outlet has some higher spec PW's for excellent prices, thaen if you shop around you will get a DA kit with pads and polishes..
    Jobs a good 'un..
    nally's Avatar
    MPG the new BPH
    May 2010
    Liverpool
    2,102
    Quote Originally Posted by scotty76 View Post
    normal ten day wash lol
  1. Which Pressure Washer?
    By _GRP_ in forum Detailing
    Last Post: 11th July 2011, 20:45
  2. Pressure Washer Suggestions
    By CHRIS555 in forum Detailing
    Last Post: 8th December 2010, 21:42
  3. Pressure washer
    By EnzoS4 in forum Detailing
    Last Post: 25th March 2009, 17:03
  4. Pressure washer info
    By dantheman in forum Detailing
    Last Post: 1st December 2008, 15:01
  5. Pressure Washer
    By deuce in forum Detailing
    Last Post: 10th January 2008, 09:50
