Sky InsuranceAH Fabrications
Results 1 to 9 of 9
    imported_kris_tdi
    cleaning the chrome window trim
    as above it looks foggy, tried a bit of polish on it but it didnt do anything, any suggestions?
    Oct 2003
    South Wales
    2,942
    Re: cleaning the chrome window trim
    What about solvol autosol available from Halfords? Or any chrome cleaner?
    scoTTy's Avatar
    Essex, UK
    1,958
    I wouldn't go for metal polish. Isn't the chrome plastic coated?
    imported_kris_tdi
    yeah i think it is coated plastic, why i was wary of using even paint polish on it.
    Mcgough's Avatar
    Oct 2004
    Newcastle
    820
    Listen guys i swear by autoglym, I used to have a set off chrome wheels and used alloy wheel seal, its in a spray can and you can use it on your allos if you dont like it, it sprays a white mist which you just rub once to finish the job!!
    Lowride's Avatar
    Sep 2003
    Warwickshire
    133
    Definetly put some polish on mate, if it does`nt get u the right results use some polish with a bit of cut in it. It would be very hard to damage the chrome trim using polish
    dreddg's Avatar
    Jan 2005
    Kent, UK
    81
    Hi all
    I am also experiencing the same problem with my roof rails...I have tried autosol and car polish but no joy
    I was thinking about using wire wool....what do you reckon???? [img]/ubbthreads/images/graemlins/noidea.gif[/img]
    Jul 2005
    2,488
    dont know if its a plastic coating or a laquer finish, but wire wool is definately not the way to go.
    if it is a laquer, you could try a tcut for metallic cars.
    dreddg's Avatar
    Jan 2005
    Kent, UK
    81
    [ QUOTE ]
    [/ QUOTE ]
    Hi Mad
    Thanks for the info...i will give it a go, i was also thinking of giving it a go with a polish mop, with the high speed it may clear the fogging....will post my results on here if succesful. [img]/ubbthreads/images/graemlins/book.gif[/img]
