W8 PerformanceJuicy
Results 1 to 8 of 8
    james b's Avatar
    Jul 2007
    80
    Post Thanks / Like
    S3 Engined MK2 Golf detail
    Something a bit different from us here, the owner of this tidy little number contacted us to help get it in shape ready for sale, as im currently working on my own little MK2 project i was pretty interested in this one, so after a bit of a chat we decided to get it in for a one day "dusk till dawn" type enhancement treatment, and do what we could with it in a day:
    On arrival:
    Packing a bit of heat (this woke me up in the morning driving it in to work i can tell you :tumbleweed
    First up was the rims, using Imperial:
    Shuts and engine pre sprayed with Citrus Power:
    Jet washed down and the washed TBM with a drop of Lather:
    Once all cleaned and rinsed off, we set about claying the paintwork:
    Dried off and taped up we cracked out the machines and a bottle of Rejuvenate and a polishing pad and set about knocking some of the swirling and hazing out of the paintwork & adding some clarity to it:
    Before:
    After:
    Ben got busy polishing up the tail pipes:
    contact admin to advertise
    james b's Avatar
    Jul 2007
    80
    Post Thanks / Like
    And the trim with a bit of Revive
    We managed to source a set of original centre caps as one was missing:
    Add a couple of coats of spirit:
    Detail the interior:
    And this is how it came up:
    Obviously alot more than the stages pictured went in to this job, the interior was fully cleaned (as you can see) the bay had alot of cleaning and polishing from Mike) and the trim etc had a very detailed clean prior to applying dressings to get it just right, but with just a day to turn it around and 3 of us all working on it at times i could only get pictures of so much.
    I hope you enjoyed the write up, we have a few more "dusk till dawn" turn arounds to show you.
    James
    arnoldlog's Avatar
    58
    Post Thanks / Like
    wow!! loving the s3 engine
    jojo's Avatar
    Joker of a Moderator
    Sep 2003
    Solihull, Midlands
    19,579
    Post Thanks / Like
    I was expecting 1.8T, not 2.0T! Awesome!!
    You've got to have a laugh!
    99' Audi S3(APY) - Brilliant Black, it's back!
    Ben H's Avatar
    On a journey...
    Jul 2009
    Bristol
    294
    Post Thanks / Like
    That's got to be running at least 250bhp per ton?!
    S3 Sportback S-Tronic (2010) - c. 310bhp
    Brilliant Red, RNS-E 2, CD-changer, Bluetooth, Bose, aluminium roofbars... and two childseats
    Aug 2009
    Costa del Cardiff
    453
    Post Thanks / Like
    I want that car!!
    Mar 2011
    68
    Post Thanks / Like
    Quote Originally Posted by Ben H View Post
    Standard GTi weighed approx 1 ton (990Kg I think) however you would expect the 2.0T to be slightly heavier than the 1.8 16v unit. I would also expect S3 gearbox etc and bigger brakes to have been bolted on and it not still running to old 256mm discs which were prone to fade at the best of times.
    That said I'd be surprised if it was much than heavier than 1.1 ton so standard power would see around 240bhp/ton and tuned could be 270-300+/ton. Either way it will be bloody quick
    Wonder how much it is going for? I would expect it to struggle with traction in dry let alone wet as the standard GTi was poor at getting off the line when wet. I'd imagine a full 4wd conversion would be awesome. I recently drove a standard 1990 GTi after owning one for years and compared to our modern, refined, safer cars, thank goodness for progress. It still had great driver involvement but no where near as fast as I remembered and certainly not worth going back to. At the time the GTi was the car to have but that was 20+ years ago.
    Nice detail, as a big Mk 2 fan it is nice to still see some of them around albeit in non standard guise.
    nally's Avatar
    MPG the new BPH
    May 2010
    Liverpool
    1,945
    Post Thanks / Like
    where you based want to see how much correction is
    2009 (58) plate audi A3 Sline 2.0TDI, DRL's with washers, Half Leather / Alcantara, I Pod Aux, 15% tints / EM tuning L.E.D. interior upgrade.
    Pressed plates on their way.
  1. Mk2 Golf Project
    By S90GAV in forum Volkswagen and other VAG
    Last Post: 26th November 2011, 17:21
  2. Twin engined Golf!
    By jojo in forum General Automotive Chat
    Last Post: 28th June 2010, 22:59
  3. mk2 golf
    By leigh@vagtech in forum The Cool Wall
    Last Post: 25th February 2009, 22:09
  4. S3 or Mk2 Golf Gti?
    By Spacecowboy in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th June 2007, 23:27
