DPMBackdraft Motorsport
Results 1 to 27 of 27
Like Tree2Likes
  • 1 Post By Jimmeh
  • 1 Post By Jimmeh
Thread: Audi TT - 3 day Major
    Jimmeh's Avatar
    Mar 2006
    East Midlands
    1,413
    Post Thanks / Like
    Hi all - here's my latest Audi installment that may be of interest.
    Audi TT – Major Paint Correction Detail
    Take an Audi that has clocked 85k miles, been through the hands of 8 previous owners and is 9 years old. Unless it’s been properly cared for in the past, chances are, it’s ready for a bit of TLC!
    Over three days my aim was to put as much life back into the paintwork as possible, tidy the engine bay and fully deep cleanse the interior with leather treatments.
    Product: AMDetails. AutoSmart. BlackFire. Jeffs Werkstat. LTT. Menzerna and Scholl Concepts.
    The vehicle was put through its wash stage late on a Sunday evening – “why?” Monday, first thing, I had organised a dent repair chap to pull a few of the nasty dings out. No photos unfortunately, but I must say, he did a fantastic job! (Watch this space)
    Picking up where I’d left off, surface contaminants were removed by using a clay bar.
    Lots of pick up to be seen:
    With the car now ‘clean’, it was blown dry to remove excess water from panel gaps, trim, badges etc and then taped up in readiness for some machine polishing.
    It was noted that A) the wheels had been badly refurbed (blown over the front-facing but lots of overspray and dirt stuck in the inner rim), B) the front bumper had been repainted and C) the rear bumper had been repainted (badly)
    Inspection shots.
    Resprayed areas:
    Dull and hazy:
    Wings covered in overspray and buffertrails:
    Rear bumper, an area of caution this due to the poor spray work:
    Lower down on rear bumper, there was NO life at all!
    Other than that, general swirling and bad scratches!
    Even with the nature light from the window, you can see how bad some areas were:
    More nasties:
    Overspray:
    More buffertrails from previous machine polishing:
    A few areas that really were quite tatty:
    And a bird etching thrown in to complete the set:
    Good. OK. Plenty to get stuck into then!!
    Paint thickness readings on the bonnet: (enough to play with)
    Audi A4 Avant 1.9TDi 130 Quattro Sport.
    WhiteDetails.co.uk - Facebook? Follow me!
    Jimmeh's Avatar
    Mar 2006
    East Midlands
    1,413
    Post Thanks / Like
    My first 50/50:
    Corrected and refined.
    The TT isn’t an easy straight forward shape to work with… Lots of flowing curves but also fiddly areas that require special attention and lots of tape to safely cover.
    Top of the boot lid, before/after:
    Side of the boot lid, before/after:
    Roof, with healthy paint thickness readings, before/afters:
    Refined and sharp:
    A-C Pillars - before, in-action, after:
    Keeping the correction as ‘tight’ as possible, the smaller flat sides to the wheel arches were hit first with a series of spot pads:
    …before the rest of the area was tackled. 50/50:
    Wing mirror housing before/after:
    More spot pad work – before/after:
    Insides of the grab handle polished with Menz 203s – before/after:
    50/50 on the offside between the wing and the door:
    Before/after:
    Audi-Rog likes this.
    Jimmeh's Avatar
    Mar 2006
    East Midlands
    1,413
    Post Thanks / Like
    The section around the fuel filler was a nightmare. Patience, overlapping tape and slow passes required here.
    Before/after:
    Before/after:
    O/S/R wing complete:
    The boot lid was in a bad way. Someone, somewhere down the line, seemed to have a habit of resting things on the paint whilst opening up…
    Closer up:
    Time to get aggressive.
    First up, the angled leading edge was hit first – before/after:
    And after some heavy hitting with wool, I was left with these results:
    Most impressive!
    Something you don’t often see, my own buffertrails! (Numerous ‘heavy hits’ with an aggressive polish/pad combo takes its toll)
    After refining stage:
    Before/after:
    Spoiler before/after:
    Boot lid after:
    Light clusters before/after:
    Final section on the boot – before/afters:
    Jimmeh's Avatar
    Mar 2006
    East Midlands
    1,413
    Post Thanks / Like
    Spinning the car round, work beings on the N/S.
    N/S/R wing before/after:
    “hmm, overspray!”
    N/S/R complete:
    Correction around N/S door handle:
    And front wing, before/after:
    Finalising work on the bonnet:
    Check out the difference in clarity in this next photo… Clarity between the top of the bumper and the bonnet itself:
    Bulk of the correction now complete. Just the bumpers and sills to go.
    Before/after:
    The O/S/R corner had a nasty scrape on it… Treading carefully here as the paint finish wasn’t the best.
    Before/after:
    The only way the rear bumper will ever be perfect is if it has another (proper) respray. Much improved though for now…
    Lower down, the scrape continues – before/after:
    Little middle section – before/after:
    And finally the lower part that had no life at all.
    Better:
    Jimmeh's Avatar
    Mar 2006
    East Midlands
    1,413
    Post Thanks / Like
    Sill work – before/after:
    The leading edges were a bit rough; 9 years of people clobbering them with their shoes.
    Attempted befores and afters:
    and the O/S:
    Before/after:
    With heavy paint correction comes heavy dusting! Before we can think about wax, protection, glass etc, we need to rid all surface debris.
    After a quick foam, a thorough pressure wash was given; concentrating on trim, panel gaps, crevices, sills and shuts etc…
    Rinsed with an open hose to sheet the water off of the panels (far easier to dry afterwards!)
    With the car back inside, fully dried down, engine bay dressed and paintwork wiped with IPA, I looked towards the protectional stages.
    Product of choice? Had to be BlackFire.
    BlackFire ‘Wet Diamond’ All Finish Paint Protection.
    Allowed to cure for 15 minutes before buffing.
    Although out of focus, these next shots are before/afters on the exhaust tips. Belgom Alu and 00 grade wire wool. Came up quite good in the end!
    Glass cleaned, exterior ‘toothpickery’ (removal of remaining trapped residues etc) and wheels sealed. Time to check out that interior…
    Doesn’t show too well on the photos, but, lots of room for improvement. Shiny, dirty leather. A dirt encrusted gear knob, tacky indicator stalks and grubby plastics all round.
    Leather ‘brushed’ to remove trapped dirt from sides of bolsters. Hoovered. Plastics wiped with weak AS G101 mix. Toothpick used to lift engrained dirt in gear knob numbering and finally the Leather was deep cleansed with LTT’s Auto Ultra Foam. (Re-hoovered!)
    After:
    Jimmeh's Avatar
    Mar 2006
    East Midlands
    1,413
    Post Thanks / Like
    Boom. Three days later, we have an Audi TT fit for ANY showroom!
    Correction levels:
    Enjoyed this one! Both physically working on the car and documenting it! An awesome ‘save’ and a mega turnaround.
    My ‘Pamper-Pack’ kit (essential DIY products) was passed on to the new (delighted) owner and they hope to revisit in 3-4 months for a top up.
    As always, thanks for reading and thanks for the continuous support!
    Jim
  8. Likes ScottB5, StateOfPlay, Smokey_clark liked this post
  9. #7
    Ben H's Avatar
    On a journey...
    Jul 2009
    Bristol
    294
    Post Thanks / Like
    That is an absolutely stunning turnaround - really enjoyed seeing this.
    S3 Sportback S-Tronic (2010) - c. 310bhp
    Brilliant Red, RNS-E 2, CD-changer, Bluetooth, Bose, aluminium roofbars... and two childseats
  10. Thanks Jimmeh thanked for this post
  11. #8
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    11,554
    Post Thanks / Like
    Absolutely stunning Jim
  12. Thanks Jimmeh thanked for this post
  13. #9
    sean_s3's Avatar
    May 2009
    West Yorkshire
    209
    Post Thanks / Like
    Awesome work , I bet the new owner hardly recognized the car the differance is so big.
    2001 S3, BLACK. Stage 1 Remap, Polished Door Mirrors, Colour-coded side diffusers & Rear Bumper Center, Bose, Pristine Condition 18" RS-TT alloys.
  14. Thanks Jimmeh thanked for this post
  15. #10
    HerefordQuattro's Avatar
    Hereford
    250
    Post Thanks / Like
    stunning work Jim, was the Blackfire AFPP at clients request or your choice? looks great whatever
    A6 Avant 2.5tdi Quattro Sport 220bhp 458Nm 6 speed Manual
  16. Thanks Jimmeh thanked for this post
  17. #11
    si hoc's Avatar
    Jan 2011
    middlesbrough
    108
    Post Thanks / Like
    nice work mate
    07 a4 2.0tdi s line avant
  18. Thanks Jimmeh thanked for this post
  19. #12
    kevscotty's Avatar
    Aug 2011
    19
    Post Thanks / Like
    nice work how much does a detailing like that cost if you dont mind me asking?
  20. Thanks Jimmeh thanked for this post
  21. #13
    Syvo's Avatar
    IF IN DOUBT GO FLAT OUT
    Jan 2011
    warrington
    1,222
    Post Thanks / Like
    im speachless m8 that is the best correction work ive seen
    Mods:
    BBS ch 18x9j - Powerflex red dog bone - Powerflex front wishbones - turbo smart boost gauge - forge FMIC - HKS induction kit - forge 007p - Fk street coilovers - Forge rear Tie Arms - 11mm FK Spacers - Hid 6K - S3 washer&coolent cover - S3 Carriers - pipe werx Cat Back - SFS Tip
    To-Fit
    front drop links
    TO-Buy:
    3" down pipe - 200cell Cat - r32 Rear arb - S3 Rear bumper - new headlights - new rear lights - Oil Catch can - Forge Quickshift - falken 452's
  22. Thanks Jimmeh thanked for this post
  23. #14
    Smokey_clark's Avatar
    12th Gear
    Nr Bath
    207
    Post Thanks / Like
    Great job there Jim!
    I am also intrigued with what you might expect to pay for just the paint correction work.
    I can keep my interior clean and don't have much of a problem protecting and cleaning my paint but i suffer with the condition the car came to me in the first place! Wish i had the balls to get a polisher onto it!
  24. Thanks Jimmeh thanked for this post
  25. #15
    Jimmeh's Avatar
    Mar 2006
    East Midlands
    1,413
    Post Thanks / Like
    Thank all!
    Quote Originally Posted by Ben H View Post
    Cheers Ben. Must admit, can sometimes take as long to write the report as it does to wash the car in question! (worth it in the end tho! )
    Quote Originally Posted by HerefordQuattro View Post
    Was my choice. It's to be a regular visitor for top-ups etc so for ease of use and looks, it was 'the one'!
    Quote Originally Posted by kevscotty View Post
    Quote Originally Posted by Smokey_clark View Post
    Pop over an email if you could guys or find me on FB on the link below. Cheers!!
  26. #16
    Hereford
    250
    Post Thanks / Like
    not posted this one on detailing world yet mate?
  27. #17
    Audi-Rog's Avatar
    "Fire up the Quattro!"
    Dec 2009
    Milton Keynes, United Kingdom
    127
    Post Thanks / Like
    Awesome work Jim! Superb turnaround mate!
    That's why I went into Detailing (part-time) myself! The pure satisfaction of reviving/rescuing a really poorly looked after car and making it desirable again, is priceless!
    Loving your work ethic too, so much passion, skill and pride, it really shows! And it's the reason you are so busy!
    Rog
    | Audi S4 B6 4.2 V8..gone | A3 TFSI Q S line..gone | Octavia II 2.0 TFSI VRS Estate|
    |Pipercross Panel Filter| Carbonio CAI | Link:FREEMAN:detailing Beds, Bucks, Herts Area|
  28. #18
    Jun 2009
    Hartlepool
    106
    Post Thanks / Like
    Stunning work Jim and a top class write up matey
  29. #19
    Feb 2008
    2,545
    Post Thanks / Like
    great work Jim. How come you dont seem to be on DW recently?
    2000 AMK S3, Revo'd, forge 007p, H&R's, tarox g88's, ferrodo ds2500's, and in the fastest colour
  30. #20
    Wozski's Avatar
    469
    Post Thanks / Like
    Drools!!!
  31. #21
    nally's Avatar
    MPG the new BPH
    May 2010
    Liverpool
    1,945
    Post Thanks / Like
    love looking at these just wish i could do it
    2009 (58) plate audi A3 Sline 2.0TDI, DRL's with washers, Half Leather / Alcantara, I Pod Aux, 15% tints / EM tuning L.E.D. interior upgrade.
    Pressed plates on their way.
  32. #22
    Feb 2009
    Cheshire
    41
    Post Thanks / Like
    very impressive!
  33. #23
    rasA4's Avatar
    Four Rings Mafia Specialist
    Apr 2003
    Deep
    3,059
    Post Thanks / Like
    as always top job, what do you use and the method for rear lens to get rid of the scratches?
    Bee Five | A4 2.4 V6 30V Tip SE | OEM S4 Alloys | S4 Bumper | S4 Leathers | HIDs| Billy's & Bachs | I Aint new to this | Hit the THANKS Button if my post is any use |Thanks!
  34. #24
    A-k
    Sep 2011
    76
    Post Thanks / Like
    Great turn around black is a great colour for seeing results
  35. #25
    Jimmeh's Avatar
    Mar 2006
    East Midlands
    1,413
    Post Thanks / Like
    Quote Originally Posted by S3 Rav View Post
    I haven't posted anything on DW in years chaps? I lurk from time to time, new products, news etc. I used to post in the Showroom a long time ago - since, I've not really looked into the Studio/Supporters scheme (seem to be doing alright as it is! )
    Quote Originally Posted by Audi-Rog View Post
    Rog
    Cheers mate - appreciated.
    Quote Originally Posted by rasA4 View Post
    I tend to reach for Menz 203s when working on the rear clusters. A light/medium cut polishing pad and low speeds to keep temps down. By hand? You could try Menz 203s on a lake country polishing pad (see polishedbliss' posts) or even the Megs Plastic-X system (no experience in using this though)
    Thanks again!
  36. #26
    Nov 2011
    50
    Post Thanks / Like
    excellent thread and great work!
  37. #27
    Steven.c's Avatar
    Auto-Motive Restored Deatail
    Sep 2011
    Shropshire - West mids
    177
    Post Thanks / Like
    seen this write up and all of your others on CYC, your work is outstanding!
  1. Replies: 8
    Last Post: 5th March 2011, 10:57
  2. Polished Bliss: Audi S5 Major Correction...
    By Clark@Polishedbliss in forum Detailing
    Last Post: 15th January 2010, 20:53
  3. MAJOR PROBLEMS AUDI 80 TDI
    By campione4 in forum Classic Audi Forum
    Last Post: 12th May 2009, 20:25
  4. MAJOR PROBLEMS AUDI 80 TDI
    By campione4 in forum General Technical / How To
    Last Post: 6th May 2009, 09:23
  5. Major price drop Audi A4 1.8TQS
    By Bong Water in forum A4/S4 forum(B5 Chassis)
    Last Post: 22nd July 2008, 09:09
