As it says in the title what is the best way and products to clean and polish my rear lights on my audi coupe any b efore and after pics would be great![]()
Hope the people that took me DIE
A4 nut thanked for this post
What polish?
I've had good results on rear lights using 3m Yellow spot pad and Megs 205 via rotary.
2003 Audi A4 Avant-tdi 130-Remapped, Allard EGR Pipe, Smooth airbox, HIDS, Flyeye kit, de-chrome grill, de-badged.
Coming soon-18s or 19s
Meguiar's 205 and a yellow pad would be fine.
The plastics are really quite soft so there's no need to use anything too aggressive (the current fad for wet sanding headlights is completely un-necessary)
I tend to use Menzerna 203S Menzerna Power Finish (203S) | Menzerna Car Care & Detailing Products with a Light Cut Lake Country pad on the machine: Lake Country 100 mm Constant Pressure Pads | Lake Country Car Care & Detailing Products - watch your temperatures as the plastic doesn't dissipate heat like a metal panel; too much heat and you'll distort the plastic.
You can get a good result using 203S by hand with a Light Cut pad: Lake Country Light Cut Hand Pad | Lake Country Car Care & Detailing Products
I couldn't have said it better myself John ;-)As above.Thumbs up
