DNA TuningW8 Performance
Results 1 to 21 of 21
    a3_dan's Avatar
    Aug 2009
    South London
    584
    Post Thanks / Like
    Question Viro-sol...Wheel cleaning....
    Anybody use this for cleaning their wheels? How does it compare to the dedicated wheel cleaners such as Iron-x and Wolfs etc?
    Thanks,
    Dan
    Audi TT - 2.0TFSI - Ibis White
    a3_dan's Avatar
    Aug 2009
    South London
    584
    Post Thanks / Like
    3DTDi's Avatar
    Jun 2011
    Bristol/Gloucestershire
    227
    Post Thanks / Like
    one word.........Bilberry
    A3 2.0TDi 170 S Line Brilliant Black
    Plans: FBMFSW, RNSE MkII, S3 Diffuser and Skirts, OEM Bi-Xenon
    John @ PB's Avatar
    Sep 2010
    360
    Post Thanks / Like
    a3_dan's Avatar
    Aug 2009
    South London
    584
    Post Thanks / Like
    I just bought some decon gel mate, i tried it, and yes its amazing stuff, but two of my TT wheels are still so black inside, they are just so hard to clean up! Should i just try again and maybe take the wheels off this time for better access?
    Thanks,
    Dan
    John @ PB's Avatar
    Sep 2010
    360
    Post Thanks / Like
    Quote Originally Posted by a3_dan View Post
    Thanks,
    Dan
    Yes, that's probably the best bet. I have left Decon gel on really bad wheels for several hours with no issues (obviously take care if you do this yourself - it's at your own risk!) and great results.
    a3_dan's Avatar
    Aug 2009
    South London
    584
    Post Thanks / Like
    Ok, I tried this over the weekend and my two passenger side wheels are still rotten inside :-(
    What else do you suggest I do?
    I will try take some pics tonight so you can see what im dealing with!
    Audi-Rog's Avatar
    "Fire up the Quattro!"
    Dec 2009
    Milton Keynes, United Kingdom
    127
    Post Thanks / Like
    Hi Dan,
    It could be tar build up, so you may need to de-tar the wheels using Tardis (or something similar), as Wolf's and Iron X and other wheel cleaners don't always remove this. You might need to use a stronger acid wheel cleaner or clay bar to help remove stubborn contaminants. It all depends on what is on the wheels.
    As you say, put some pics up so we can help a bit more.
    Rog
    | Audi S4 B6 4.2 V8..gone | A3 TFSI Q S line..gone | Octavia II 2.0 TFSI VRS Estate|
    |Pipercross Panel Filter| Carbonio CAI | Link:FREEMAN:detailing Beds, Bucks, Herts Area|
    a3_dan's Avatar
    Aug 2009
    South London
    584
    Post Thanks / Like
    Right guys, Please see below pics, one is of 1 of my 2 of my wheels that are built up with this black hard to budge stuff, and i have also put a pic of 1 of my other 2 wheels which as you can see are mint.... any thoughts?
    [IMG][/IMG]
    [IMG][/IMG]
    Thanks,
    Dan
    Feb 2011
    Preston
    Post Thanks / Like
    Megs wheel brightener mate shifts everything, then seal them so you can clean with a none acidic gel!
    [IMG][/IMG]
    [IMG][/IMG]
    Thanks,
    Dan
    a3_dan's Avatar
    Aug 2009
    South London
    584
    Post Thanks / Like
    I have wonder wheels lying around in my shed or is that a big no no??
    Dan
    rowdyboy's Avatar
    Mar 2009
    Derbyshire
    677
    Post Thanks / Like
    Wonder wheels will shift it, but dont leave it on long at all, 30 secs, and make sure you rinse it thouroughly before a good layer of protection. It might take a couple of coats but its better a couple of coats for a short time than leaving it on for too long. After you've protected properly, never use it again!!!
    3.0 Tdi Q A4 Avant S-Line Dolphin Grey
    RNS-E retrofitted
    a3_dan's Avatar
    Aug 2009
    South London
    584
    Post Thanks / Like
    ha thanks for the tip, Is megs wheel brightener the better option then?
    rowdyboy's Avatar
    Mar 2009
    Derbyshire
    677
    Post Thanks / Like
    You may aswell use what you've got
    RNS-E retrofitted
    a3_dan's Avatar
    Aug 2009
    South London
    584
    Post Thanks / Like
    cool ok, i will give this a go over the weekend and let you know how it goes, you think wonder wheels will shift this black hard stuff? As two attempts of wolfs had no effect...
    Ta
    John @ PB's Avatar
    Sep 2010
    360
    Post Thanks / Like
    That looks like the surface has started to corrode.
    Wonder Wheels 'might' work - however, if the surface has bubbled, the product can get under the paint/lacquer and lift it. Meguiar's Wheel Brightener is probably even more aggressive than Wonder Wheels.
    I'd try Tardis first to remove as much tar build up as possible and then see what you're left with. It does look like a refurb might be the only option.
    a3_dan's Avatar
    Aug 2009
    South London
    584
    Post Thanks / Like
    Ah dammit, I was afraid someone might say they need a refurb.
    I will try the WW, as like I said, I have some lying around in my shed. Why would the alloys be this bad on an 09 plate? My two drivers side wheels are pristine! The two passenger side wheels are both bad, weird!
    John @ PB's Avatar
    Sep 2010
    360
    Post Thanks / Like
    Have you had the car from new? If not, it could be that maybe one side has had the wheels replaced or repainted at some point?
    I've seen cars of this age with badly corroded wheels - usually as a result of lack of washing but often due to the use of very strong wheel cleaners but it is a little bit odd that it's just on one side.
    Try Wonder Wheels and give Tardis a go as well.
    nally's Avatar
    MPG the new BPH
    May 2010
    Liverpool
    1,945
    Post Thanks / Like
    Quote Originally Posted by 3DTDi View Post
    orderd today looks the sh1t. not as good as flash royal brown.
    but better than the crap i was using .
    2009 (58) plate audi A3 Sline 2.0TDI, DRL's with washers, Half Leather / Alcantara, I Pod Aux, 15% tints / EM tuning L.E.D. interior upgrade.
    Pressed plates on their way.
    Audi-Rog's Avatar
    Dec 2009
    127
    Post Thanks / Like
    That looks like tar/grease build up to me mate, use Tardis to remove it, wonder wheels and other wheel acids are good for baked on brake dust and road film, but not tar!
    Take the wheels off for better access too.
    Put some pics up once you've done it
    Rog
    a3_dan's Avatar
    Aug 2009
    South London
    584
    Post Thanks / Like
    Right guys, I had some time today to get the two wheels off, and I used Wonder Wheels, and a washing up brush, and this done the trick....but blimey did i need to use some serious elbow grease!!!!!
    I then sealed with some poorboys wheel sealent! Im hoping my wheels will remain mint now!!!
    Thanks for the advice folks!
