DNA TuningDPM
Results 1 to 32 of 32
    danb986's Avatar
    In awe of VCDS
    Apr 2011
    Hertfordshire
    302
    Post Thanks / Like
    Silver roof rails need some attention - photo's included
    Hi folks,
    I'm a newbie that's just bought an '07 A3 Sportback, which has got the silver roof rails.
    The problem is that they look waterstained and sort of flat and patchy. I gave one of them a quick polish with some Zymol I had in the garage, but it didn't really do much. I also asked at Audi and they said they didn't have anything special to clean them with.
    Does anyone know if these are lacquered or anything? I've got some Autosol metal polish, but I haven't been brave enough to use it in case I ruin them.
    Is there anything safe I can use to get these looking less patchy. I'm not even sure if they should be shiny or a more dull aluminium finish. The last photo below shows the end I gave a quick polish with the Zymol.
    Any advice would be gratefully received.
    Hopefully you can see what I mean from these pics:
    '07 TDI 140 Sportback Sport. Dolphin Grey
    Retro'd: S-Line spoiler | Votex sideskirts | Votex front spoiler | LED rear lights | LED number plate and sidelights | S/S Exhaust trims | Rear parking sensors | Come home/Leave home lights | 40% LED Fogs as DRL's | Private plate | Cruise control.
    3.2 Ju's Avatar
    Jul 2007
    Yorkshire
    998
    Post Thanks / Like
    Mines an 05 and apart from a few light scratches they are in perfect condition, no watermarking like yours just shiny! You could try a fine wire wool, we use it on glass to remove light scratches so should be ok on polished metal.
    Brilliant Red S3
    Gone
    2005 A3 3.2 quattro S-line Sportback dsg Avus silver
    2005 A3 3.2 quattro Sport Sportback dsg Black
    rowdyboy's Avatar
    Mar 2009
    Derbyshire
    677
    Post Thanks / Like
    DONT USE WIRE WOOL!!!
    Use some Werkstat prime, it'll clean them up like new. Google it to find your local stockist.
    3.0 Tdi Q A4 Avant S-Line Dolphin Grey
    RNS-E retrofitted
  5. Thanks danb986 thanked for this post
    Likes Avo liked this post
  6. #4
    danb986's Avatar
    In awe of VCDS
    Apr 2011
    Hertfordshire
    302
    Post Thanks / Like
    There seems to be a choice between Werkstat Prime Strong, Acrylic or Carnauba. I was thinking of the Strong, but as it's a fairly large bottle I'd like to use it on the rest of the car too. Which do you think would be best suited to my needs? The descriptions are almost identical on the websites.
    Also, I've got a complete newbie question - I usually use Zymol to polish the car, would I use this instead, or do I need to Zymol on top of the Werkstat Prime?
  7. #5
    3.2 Ju's Avatar
    Jul 2007
    Yorkshire
    998
    Post Thanks / Like
    I actually looked at mine close up this morning and tbh there is some slight oxidizing on the rails, however nowhere near as bad as yours. I used some fine wire wool and it brought it up lovely.
    Brilliant Red S3
    Gone
  8. #6
    danb986's Avatar
    In awe of VCDS
    Apr 2011
    Hertfordshire
    302
    Post Thanks / Like
    I think the previous owner probably didn't look at after mine as well as you have with yours. Strange really, as mine was owned by Audi before me and the interior is immaculate.
    Are they not lacquered or coated in any way then?
  9. #7
    danb986's Avatar
    In awe of VCDS
    Apr 2011
    Hertfordshire
    302
    Post Thanks / Like
    Quote Originally Posted by danb986 View Post
    Think I've just found my answer thanks to Google:
    Werkstat Prime is exactly the same as Carlack68 NSC / Klasse AIO, only more expensive (I don't believe that Polished Bliss stock the original Prime).
    Werkstat Prime Acrylic is different in that it has extra sealant added in (around 20% IIRC).
    Werkstat Prime Strong has abrasives added.
    I'd still be interested to know if I then add Zymol on top of this though
  10. #8
    rowdyboy's Avatar
    Mar 2009
    Derbyshire
    677
    Post Thanks / Like
    You need the normal or the strong prime, either will do. The bottles are only 500ml. It's a cleanser/cleaner that will clean your rails and paintwork up. I personally use Werkstat acrylic on top as the prime cleans the surface and doesn't give protection. I'm not sure if the zymol will bond properly but you'll definitely need to put a surface protectant on after prime. If you look on the polishedbliss or Werkstat website, it gives you full instructions.
    RNS-E retrofitted
  11. Thanks danb986 thanked for this post
  12. #9
    rowdyboy's Avatar
    Mar 2009
    Derbyshire
    677
    Post Thanks / Like
    I would think if Audi owned it, the paintwork has not been looked after properly at all. Look at some of the threads showing how much people have to correct main dealers poor cleaning techniques.
    If they are lacquered, wire wool certainly isn't going to help!!
    RNS-E retrofitted
  13. #10
    FranA3's Avatar
    fran the 1.6 man
    Dec 2008
    south wales
    6,711
    Post Thanks / Like
    dont ever use wire wool on them it will do more damage than good use a product like rowdyboy has suggested they are meant for cars so are designed to do the job on your car failing that some autosol metal cleaner will do it but i would only use that if nothing else is working but wire wool = scratched = even worse than to start with
    PRdetailing
    follow us on Facebook
    www.pr-detailing.co.uk
  14. #11
    3.2 Ju's Avatar
    Jul 2007
    Yorkshire
    998
    Post Thanks / Like
    They're not lacquered and yes wire wool does work without scratching. We are talking metal here guys and not a painted finish. If you don't believe me try it on some cutlery and see.
    Brilliant Red S3
    Gone
  15. #12
    FranA3's Avatar
    fran the 1.6 man
    Dec 2008
    south wales
    6,711
    Post Thanks / Like
    spoons and stuff are stainless steel roof rails are alloy are they not
    PRdetailing
  16. #13
    3.2 Ju's Avatar
    Jul 2007
    Yorkshire
    998
    Post Thanks / Like
    No worries m8, use whatever you are comfortable with. I've done mine this morning so I know it's fine
    Brilliant Red S3
    Gone
  17. #14
    Jan 2011
    424
    Post Thanks / Like
    My windscreen pillers on my cab look milky too.....lets the whole car finish down. Not found a proper fix yet...
    2003 A4 Cab 2.4 V6 Manual / 36k miles genuine woohoo / Ebony Black Metallic / Full Grey Leather / Fully Electric Seats / Heated Seats / Interior Light Pack / Cruise / Wood / Bose Symphony II / Black roof
  18. #15
    a9503128
    have you though of buying new rails? They are bolt on so once you have access from the roof lining it cant take too long.
  19. #16
    rowdyboy's Avatar
    Mar 2009
    Derbyshire
    677
    Post Thanks / Like
    Quote Originally Posted by a9503128 View Post
    £15 for some cleaner that'll bring them up like new or £££££ for new rails!!! Difficult decision!
    Cabbyfan - they are different to the roof rails and from reading other threads, the only fix is replacing them unfortunately.
    RNS-E retrofitted
  20. #17
    Jan 2011
    424
    Post Thanks / Like
    Quote Originally Posted by rowdyboy View Post
    Mmmm not paying that ha ...... Ah well.
  21. #18
    a9503128
    Genuine Audi A3 Sportback Roof Rail Retrofit Kit-Chrome | eBay UK Depends how much they annoy you but for only £550 you can have new or circa £50 you get 2nd hand ones and send to a metal polisher like Gold Plating - Decorative Precious Metal Plating & Musical Instrument Repairs in Watford and you can get a RS4 polish on them.
  22. #19
    danb986's Avatar
    In awe of VCDS
    Apr 2011
    Hertfordshire
    302
    Post Thanks / Like
    I just thought I'd report back with my progress.
    My Car-Lack68 arrived yesterday and I gave it a go last night. There are no application instructions on it, but after a bit Googling I discovered you apply it and then leave it for about half an hour to do it's stuff and draw out the oxidization, then just wipe it off.
    I tried this once and it made a little difference, so I gave it a second try. This time I gave it a good rubbing when I applied it and then I made sure there was a thick coating and left it for 45 minutes.
    When I wiped it off this time there was no improvement.
    It's so frustrating. I quite like the alloy effect, but I might have to get brutal with them and get them polished at the place mentioned above, as I'm not far from Watford.
    Has anyone else got an idea's? Or should I just keep going with the Car-Lack?
  23. #20
    Dec 2010
    59
    Post Thanks / Like
    My first try would be a paint cleaner as mentioned above, or a finishing polish, something with mild abrasives. If they are not lacquered (I don't have roof rails) then autosol.
    You also say about polishing with zymol, what zymol products do you have? What carlack product did you get?
  24. #21
    rowdyboy's Avatar
    Mar 2009
    Derbyshire
    677
    Post Thanks / Like
    Mate, I've already told you what to use to bring them back to looking like new.
    RNS-E retrofitted
  25. #22
    danb986's Avatar
    In awe of VCDS
    Apr 2011
    Hertfordshire
    302
    Post Thanks / Like
    If you're talking about Werkstat Prime, I've tried that and it did nothing except make it feel smoother. All the staining remained.
    I also tried the Car-lack stuff 6 times over the weekend, thinking it may just need persistence, but this made no difference at all either.
  26. #23
    danb986's Avatar
    In awe of VCDS
    Apr 2011
    Hertfordshire
    302
    Post Thanks / Like
    Quote Originally Posted by Padtwo View Post
    The Zymol is the cleaner wax that Halfords do, it's the turquoise stuff that smells like you can eat it
    And the Carlack was Carlack 68 NSC.
    I don't think they're lacquered because I tried absolutely every cleaning product I own (even some wheel cleaner that is supposed to be safe for unlacquered/chrome wheels) and the only thing that even looked like working was the Autosol, but only with the cotton polishing wheel on my Dremel. I worked on a little area at the back and it looks like it'll come up well, although this took around 10 minutes to do about an inch as I was being really careful.
  27. #24
    May 2009
    West Yorkshire
    1,290
    Post Thanks / Like
    Mine look just like the OPs.
    Cloudy and water stained, i'm in the process of minting the body work up of my SB, alloy wheel re powder coat, spruce the roof rails up and a swirl removal and wax.
    Audi A3 S-Line 2.0L TDI 140 Sportback (56)
  28. #25
    May 2009
    West Yorkshire
    1,290
    Post Thanks / Like
    T I worked on a little area at the back and it looks like it'll come up well, although this took around 10 minutes to do about an inch as I was being really careful.
    You got a photo of them after?
    I've tried all sorts to clean mine too, it's getting on my nappa now.
  29. #26
    danb986's Avatar
    In awe of VCDS
    Apr 2011
    Hertfordshire
    302
    Post Thanks / Like
    Quote Originally Posted by AidenUK View Post
    You can see that as you get towards the middle of the roof rail it's the original water stained colour, but at the end you can see how the Autosol and Dremel has brought it up brighter.
    The part that's still all stained has had 2 attempts with Werkstat Prime and 5 tries with Carlack 68 NSC.
  30. #27
    May 2009
    West Yorkshire
    1,290
    Post Thanks / Like
    Hmm, i don't think i could be steady enough with the dremel, i'd be bricking it just in case caught the paint. It does seem to have made a very good difference though!
  31. #28
    danb986's Avatar
    In awe of VCDS
    Apr 2011
    Hertfordshire
    302
    Post Thanks / Like
    I held a plastic spreader under the bits I was working on with a big enough gap and put masking tape around the rest.
    The biggest worry was with the chuck on the Dremel. The polishing wheel I had was very small, so I had to be really careful not to let the chuck, which is spinning at the speed of the wheel, touch the rail or it'd put a nasty scratch into the metal.
    I think I'll look at getting a bigger polishing wheel before I do the rest.
    The only thing is, it seems to make it quite shiny. I'm not sure whether they're meant to be a matte metallic aluminum colour, or whether they're meant to be as shiny as I've made that end. It seems that the only way to get rid of the staining is to polish them up to shiny though. Or get them wrapped
  32. #29
    May 2009
    West Yorkshire
    1,290
    Post Thanks / Like
    I wouldn't get them wrapped on your car, with it being a dark coloured car you wouldn't notice them as much.
    Shiny silver/polished all the way for me!
  33. Thanks danb986 thanked for this post
  34. #30
    Jul 2011
    Gateshead
    50
    Post Thanks / Like
    you could try using a fine scotch brite pad after polshing with the dremmell if you want a more satin look, working straight along the length of the rail. This technique is used in s/steel and ally fabrication. you can get different grades of scotch brite depening on the look your after and iff you dont like the look you can always re-polish with the dremmel. Andy.
    2000 A4 Avant 2.4 V6
  35. Thanks danb986 thanked for this post
  36. #31
    danb986's Avatar
    In awe of VCDS
    Apr 2011
    Hertfordshire
    302
    Post Thanks / Like
    Quote Originally Posted by melteddrummerr View Post
    Thanks, that's a good idea. I remember people doing this on the 'chrome' interior door handles in the Golfs to make them look like the R32 satin ones.
    I'll see how shiny looks and then I might give it a try.
  37. #32
    Jul 2011
    Gateshead
    50
    Post Thanks / Like
    your welcome bud, let us know how you get on.
Tags for this Thread
