Badger5Monster Motorsport
Results 1 to 26 of 26
Thread: MUCK OFF
    phoenixv6quattro's Avatar
    staylowmovefast
    Sep 2009
    wycombe
    1,394
    MUCK OFF
    Hello Gents. Just for info, "muck off", the motorcycle cleaner/mountain bike cleaner sold in Halfords strips wax quite effectively! It stripped the colly 476 I had on my avant. I my foam lance up with and sprayed it on the car, left it on for 5 mins and rinsed. Good stuff, and readily available from halfrauds! Just over a fiver too.
    IT COULD ALWAYS BE WORSE SO KEEP ON SMILING
    staylowmovefast
    Sep 2009
    wycombe
    1,394
    Anyone else tried this for the purpose of stripping wax or is it just me?
    Syvo's Avatar
    IF IN DOUBT GO FLAT OUT
    Jan 2011
    warrington
    1,337
    think its just you m8 i normally just use snow foam to strip down wax
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,956
    I've used it on motorbikes and mountain bikes but never on a car.
    Thought about using it for the alloys, engine or wheel arches.
    What do you mean what you say strip down wax?
    New Car, New Thread: Scott's Akoya Silver A8
    Gone But Not Forgotten: Audrey's Build Thread
    Syvo's Avatar
    Jan 2011
    warrington
    1,337
    takes off the wax coating so all the polish wax etc will be taken off,
    this way you have to re wax and detail the whole car i usually do it every 3 months how far its strips the wax down i dont know i use snow foam which i dont think attacks the wax that much but breaks down everything else ready for a full detail.
    one bad note if you dont get the wax on that day = damaging paintwork, i allways plan ahead for a good day to do this
    drmole's Avatar
    Apr 2010
    Mountain Ash, Rhondda Cynon Taff, United Kingdom
    1,564
    y would u want to strip the wax isnt the idea to build up a protective coat of a few layers of polish/sealent/wax?
    My A4 Detailed and finished with Zymol Glasur
    http://www.audi-sport.net/vb/detaili...ol-glasur.html
    A4 S-Line SE 220BHp with full Black pack With black badge (rear one still to fit) two tone Leather, Bose, phone prep in centre arm rest, IPOD conection RS4 pedals suede gear knob handbrake and steering wheel R8 oil Cap
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,956
    Quote Originally Posted by paul syverson View Post
    Sorry for the thread Jack phoenix.
    Why do you want to remove the wax?
    I all ways thought it was good to have it on there and more the better.
    Syvo's Avatar
    Jan 2011
    warrington
    1,337
    i think the whole idea is to remove any impurites that may get in the first coat of wax same as when you clay your car you remove the impurities although some are hard to remove as they stick in the wax.
    staylowmovefast
    Sep 2009
    wycombe
    1,394
    Bi-annualy, I strip off the wax (used to use dodo juice strong wash-but its a pain in the arse as I had to get it mail order!), remove tar and tree saps etc via tardis (great stuff), clay to further remove impurities and polish by hand. I then re-apply a good wax (this time its Blackfire). I do this process twice a year, usually in the spring and the Autumn (a summer and winter protective detail respectively). Its good practice. Just takes a while (usually 2 days)!
    drmole's Avatar
    Apr 2010
    1,564
    Quote Originally Posted by Axios View Post
    thas wa i thought but suppose if ur only doing twice a year as he does it seems good practice then
    Syvo's Avatar
    Jan 2011
    warrington
    1,337
    i think it is a very good idea as when applying wax if you miss any bits or any impurities get under the wax and you keep banging layers and layers on the impurities are still going to be there so stripping the wax off and starting from scratch is very good idea
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,956
    That makes sense, thank you.
    Never thought about it like that.
    Thanks.
    drmole's Avatar
    Apr 2010
    1,564
    another good method told to by the guys in PRD is to use IPA before each wax coat this insures no inpurities are lurking on the body or in the wax coat
    Syvo's Avatar
    Jan 2011
    warrington
    1,337
    IPA wats that?
    drmole's Avatar
    Apr 2010
    1,564
    IPA wats that?
    Isopropanol Alcohol (IPA) is an alcohol-based chemical cleaning agent esigned to remove oil and residue from painted surfaces.
    After machine polishing it is useful to spray a 50:50 mix of IPA and water onto the paint to fully remove any traces of polish and oil residues from the compounds. IPA strips back the residues that can fill and mask minor imperfections showing the true condition of the paint.
    It is also very useful to use IPA before applying a sealant or wax to allow the subsequent layers to fully bond giving increased durability to the finished product.
    500ml
    thas from Clean Your Car website
    Syvo's Avatar
    Jan 2011
    warrington
    1,337
    so would this only be effective on machine polish or hand polishing also?
    drmole's Avatar
    Apr 2010
    1,564
    its designed to remove all residues n comtaminants so would work well for either as far as my understanding it jus ensures the cleanest possible surface to apply ur products too its more used for machine work as the compounds leave more residues
    im sure some 1 more knoweldgable will explain better
    staylowmovefast
    Sep 2009
    wycombe
    1,394
    TBH I only use IPA on my windows. It is strong stuff and will more than likely strip the wax if you apply it (if you havnt stripped the wax off first!).
    John @ PB's Avatar
    Sep 2010
    360
    Quote Originally Posted by drmole View Post
    IPA will strip wax. Don't apply it between coats of wax as it'll remove the ones already there.
    It's best applied after polishing, prior to wax application.
    Syvo's Avatar
    Jan 2011
    warrington
    1,337
    so would you polish then ipa then pre wax and then wax?
    or does the ipa act as a prewax?
    John @ PB's Avatar
    Sep 2010
    360
    Polish, then IPA to strip the polishing oils, ensuring you have true correction.
    Some polishes 'fill' slight scratches, and these oils will, in time evaporate - this is often referred to as drop back.
    Pre wax cleaner next as it'll leave a base layer, ready for wax application. Many pre-wax cleaners are deliberately oil rich to ensure better bonding between them and the wax; hence better durability.
    Syvo's Avatar
    Jan 2011
    warrington
    1,337
    would this ipa stuff be essential if i was using p1 nano polish? as it doesnt contain any fillers
    John @ PB's Avatar
    Sep 2010
    360
    I have no idea about P1 but I'm sure it'll have some kind of polishing/lubricating oils in it - IPA should be a vital step after polishing.
    Juicy Jen's Avatar
    Jen – Juicy Detailing
    Jun 2011
    County Durham
    835
    Gtechniq P1 is a water based polish rather than oils and they state it doesn't contain any fillers however I always use IPA just to ensure that 'drop back' doesn't happen and that the area has been corrected. Tbh I use IPA throughout a detail rather than at the end to check work as your going along.
    In regard to hand polishing most polishes on the Market would generally contain fillers as it makes the job a lot easier, therefore if you use IPA after it's going to undo some of your hard work. Best to wax/ seal in as eventually over time the fillers will wash out anyway.
    Other reasons for wanting to strip off the wax / polish besides the general 2 times a year would be if your looking to try a new product. You'll always get a better result by preparing the surface and by ensuring there is no contamination means that the results will be much better.
    In regard to layers of wax ideally 2 to 3 layers as more is just a waste
    staylowmovefast
    Sep 2009
    wycombe
    1,394
    Talking
    THREAD HI-JACK!!!!!!LOLOLOLOL!!!!!!!
    Syvo's Avatar
    Jan 2011
    warrington
    1,337
    Sorry M8
