Sky InsuranceAH Fabrications
    imported_MADEIRA
    audiA6 cream gunge on oil fill cap
    my A6 2.8 quattro /98 i have noticed it has abuild up cream gunge on the oil filler cap,no oil in coolant tank any ideas about it please,i am worried,i only use the car for short runs,weather v/cold
    arthurfuxake's Avatar
    Controversial & Contradictive
    Mar 2004
    Manchester
    1,306
    Re: audiA6 cream gunge on oil fill cap
    sounds like water getting into your oil. could be leaking head gasket. I'm no expert, but i had that on an old rover of mine at about 120000 miles and it was the head gasket.
    fallmonk's Avatar
    Turbo Sport
    Jun 2004
    Glesga,home of the rain god!
    1,836
    DEFF water in the oil, unless u have used a oil to top it up that has been outside with the posibility of water getting in there , its your head gasket! get it looked at ASAP
    Herts,uk
    22
    could be the engine not geeting up to temp and not buring of the water in the oil from the breather system. have this alot in the winter in my car as i do alot of short runs but as soon as you go for a good run it goes.
    imported_MADEIRA
    hi dc2,thanks for the advice took car for along run no more gunge .problem solve,.cheers mate.
