Badger5Chris Nott
Results 1 to 14 of 14
Thread: which is better
    vw754's Avatar
    vorsprung Durch Technik
    Nov 2006
    U.K
    1,973
    which is better
    is this meguiars Quick clay any good and is 50g clay bar and the lube that comes with it enough to do 2 cars? or is it better to buy bilt hamber 200g soft or regular clay and use water?
    Full leather/19"wheels/cruise/
    CMD
    CMD's Avatar
    Pointing Forward's!!!!!!!!!
    Nov 2008
    S. Wales
    3,021
    Regular is fine if you are claying the car for the first time, there is no need to use the whole bar (cut in half) .Use a tar&Glue remover on the lowers / sill's, using t&g on these area's will clear most of the road tar and grime and will save you clay bar from getting wrecked .
    AUDI A4 190T S-LINE.
    S4twiggy's Avatar
    Fully Certified Detailer!!
    Feb 2009
    South Wales
    1,811
    for a lube just use water with a dash of shampoo in with it. no point buying expensive clay lubes mate when water and shampoo does the same job
    Syvo's Avatar
    IF IN DOUBT GO FLAT OUT
    Jan 2011
    warrington
    1,337
    sonus clay bar with either poorboys lube or dodojuice bornslippy it is true what twiggy says but i have tried that method and just using water method and find using the poorboys or dodojuice makes it easier and helps with the clay bar lasting as it does not cause sticking as the water i found kept drying off.
    FranA3's Avatar
    events moderator
    Dec 2008
    south wales
    7,124
    Quote Originally Posted by S4twiggy View Post
    i always use water with a little shampoo in it ive never had a problemo with it i dont see the point either its just wasted money in my opinion
    ​She is back on the road yay!!
    drmole's Avatar
    Apr 2010
    Mountain Ash, Rhondda Cynon Taff, United Kingdom
    1,564
    and y do to use shampoo on our cars boys?...............................coz were worth it!
    My A4 Detailed and finished with Zymol Glasur
    http://www.audi-sport.net/vb/detaili...ol-glasur.html
    A4 S-Line SE 220BHp with full Black pack With black badge (rear one still to fit) two tone Leather, Bose, phone prep in centre arm rest, IPOD conection RS4 pedals suede gear knob handbrake and steering wheel R8 oil Cap
    FranA3's Avatar
    events moderator
    Dec 2008
    south wales
    7,124
    Quote Originally Posted by drmole View Post
    well our cars are worth it anyway lmao
    drmole's Avatar
    Apr 2010
    1,564
    Quote Originally Posted by FranA3 View Post
    would head n shoulders stop the white dust settling too?
    on a more serious note was looking on clean your car website n noticed the sell alcohol to clean the pannels before applying wax/polish after claying this worth doing??
    CMD
    CMD's Avatar
    Nov 2008
    S. Wales
    3,021
    When polishing a car with a Rotary/DA use IPA (alcohol) to wipe down the panel to inspect the level of correction. IPA will brake down the oil's in the polish, it also saves time buffing off the polish after each pass . We buy IPA in bulk which needs to be diluted with water, it's a must have product.... Darren I can bring some to the meet on Sunday .
    Apr 2011
    USA
    11
    I use Meguires polish every time..Produce little dust and also smells good than other polishes..I only use Clay bar if there is lots of dust, swirls road grime...And yes no brushes of towels,only use micro-fiber cloths...
    S4twiggy's Avatar
    Feb 2009
    South Wales
    1,811
    claying only needs to be done twice a year, unless your about to machine polish the car otherwise it will ruin your pads. i only clay my car twice a year but dont do much mileage so it stays pretty clean. ive seen some serious contaminated panels and will ruin a bar asap
    drmole's Avatar
    Apr 2010
    1,564
    Quote Originally Posted by CMD View Post
    cheers col so its really used to de-comtaminate the paint before appling products and not used inbetween coats good to know
    CMD
    CMD's Avatar
    Nov 2008
    S. Wales
    3,021
    IPA is not designed to clean the paint as such, it's job is to wipe off the oils after the polish has broken down when using a rotary or DA. If you hand polish your car (not seal or wax) you could use IPA after the polishing to wide the panel down before appling a glaze,sealent or wax.
    drmole's Avatar
    Apr 2010
    1,564
    nice one think ill try tha cheers Col
