Badger5Monster Motorsport
Results 1 to 9 of 9
    vw754's Avatar
    vorsprung Durch Technik
    Nov 2006
    U.K
    1,973
    Bilt hamber or megs ?
    Bilt hamber (soft) clay bar has been given a 5 star rating int autoexpress clay bar test,meguiars has been given 3 stars,and bilt hamber (regular) given 3 stars.
    Im claying for the first time,ive been told by friends get meguiars clay kit its easy to use with the detailer lube but after checking reviews found bilt hamber soft is the best,but on bilt hamber site it says go for the regular if your claying the car for the first time.......but the reviews state the regular clay was too hard and struggled to even remove overspray where as the soft version is easier to use and got rid of all crap inc overspray.
    In my opinion bilt hamber is better (SOFT) should i buy that,it only needs water as a lube and is a 200g bar.....and megs needs a lube and is 50g bar,will the bilt hamber be easy and safe to use with just water?...........what are your opinions?
    2 cars to do one is not bad at all even though its never been clayed the other is tree saped.
    Full leather/19"wheels/cruise/
    FranA3's Avatar
    events moderator
    Dec 2008
    south wales
    7,124
    i would go for what ever the reveiws says is best , i use soft clay in work and just use water with it , its fine no probs at all some people rave on about using detailing spray but ive always use water and never had an issue plus water is cheaper lol you might just have to use it reularly as it dry quicker for obvious reasons
    ​She is back on the road yay!!
    May 2011
    195
    Ive used both and Bilt Hamber wins, got some of the softer stuff waiting in the garage to be used
    Paullie's Avatar
    Banana Menace!
    Jan 2011
    Aberdeenshire
    2,088
    Megs was the very first clay bar I used with the detailing spray that comes with their kit and I personally found it much easier to work with and a lot more effective than the Bilt Hamber regular clay used with water as recommended. The Bilt Hamber stuff was very sticky and it had a tendency to break up, when being used. The soft stuff may be better to work with, I know it gets good reviews for sure, but I've not used it myself. I find Sonus poly fine clay the easiest and most effective for me personally and I use Chemical Guys Synthetic QD as clay lube.
    Paulie
    MY10 S3 8P3 S-TRONIC, IMOLA YELLOW
    SHARK PERFORMANCE STAGE 2
    - GONE BUT NOT FORGOTTEN!
    vw754's Avatar
    Nov 2006
    U.K
    1,973
    Quote Originally Posted by fossie View Post
    which one? the regular one......and is it easy to use with water rather than a lube? may go for megs if bilt hamber is not all that
    moag's Avatar
    she's no d-turbo
    Sep 2010
    Northern Ireland
    819
    I use the megs clay kit and have been very happy with it. It's really easy to work with and lifted all the contaminants from the paint. Cant see how much better a clay can be really?!
    FranA3's Avatar
    events moderator
    Dec 2008
    south wales
    7,124
    Quote Originally Posted by moag View Post
    i think some are prob easyer to use than others etc...
    May 2011
    195
    Quote Originally Posted by vw754 View Post
    As far as im aware you can just use it with water. i always use something like a detailing spray
    Fossie
    Rhubarb Triangle
    3,969
    fossie - you have PM
