Volks AutosChris Nott
Results 1 to 23 of 23
    John @ PB's Avatar
    Sep 2010
    360
    Polished Bliss®: RS6 MTM...
    This was the latest one in for a bit (ALOT!) of correction work and was carried out by myself (Clark) and Alan over the space of a week.
    The car arrived looking pretty dull and a bit grubby - not surprising given the state of the roads lately:
    The leather was looking really sorry for itself due to ingrained dirt and poor dressings used by the previous owner:
    I think these 2 pictures help show the lack of shine in the paintwork:
    Alan carried out the wash process and as always, started with wheels:
    After a thorough pre rinse the wheels were sprayed with Meguiars Wheel Brightener (4:1)...
    ...agitated with Raceglaze brushes and Eimann Fabrik Wheel Woolies...
    This was followed by a rinse and then an application of Autosmart Tardis:
    Wiping any tar spots off with an old MF towel:
    Then another rinse:
    Then a new product was applied to the wheels to remove iron contamination - same idea as Iron-X and still turns purple when there's a reaction but a different product all together
    After a good agitation with the various brushes and then a final rinse the wheels were squeaky clean:
    John @ PB's Avatar
    Sep 2010
    360
    Arches and Tyres next, sprayed with Meguiars Super Degreaser (4:1)...
    A trolley jack was used to gain access to the arches incase you wondered where that huge clearance suddenly appeared from:
    The car was then foamed with a strong APC solution and left for a few minutes:
    After a thorough rinse at high pressure at a temperature of approx 60 degrees all the door shuts, exterior trim etc were cleaned with APC:
    The engine bay was then cleaned with Meguiars Super Degreaser and then the car was washed with Meguiars Shampoo Plus but no pics of this as Alan's camera batteries were charging.
    Once washed (and batteries charge a bit) Autosmart Tardis was applied to the entire car:
    Then wiped over with an old MF towel:
    This was rinsed again and then any iron contamination was then removed with the new product:
    Wiping it over with a MF towel:
    As you can see, the car bled purple for a while :D
    After another rinse off with hot water the car was put inside and clayed with Meguiars Mild:
    Very little contamination present after the chemical process carried out during the wash stage
    The car was then wiped dry with a Poorboys Waffle Weave towel (usually we pat dry but the car is about to get machined anyway so any marring induced will be removed):
    Black Baron came out to play to get rid of any excess water hiding in the panel gaps, wheels etc:
    The engine bay was sprayed with 303 Protectant in a Swissvax Mixing Bottle:
    The tailpipes were polished with Raceglaze Alutech:
    Alan decided to get the interior out the way first
    Making sure to pull the seams of the seats apart to get all the dirt out that builds up over the years:
    All interior surfaces were wiped down with APC before the attention was turned to the leather.
    Swissvax Leather Cleaner Forte was used to thoroughly clean all that grime and old product residue and bring the leather back to life:
    Before:
    After:
    And one of the best 50/50's I've seen on leather for a while!
    The leather was then fed with Raceglaze Leather Balm by bare hands to thoroughly work it in and interior glass was cleaned with Swissvax Crystal.
    Now let’s turn our attention to the paintwork:
    The entire car was covered in etchings and deep scratches so the initial plan of Alan helping with the correction stage with the Dual Action machine was put on hold as the defects were just too deep to be fully removed after a bit of time playing with some of the most aggressive combinations - the results weren't bad but they weren't to a Polished Bliss standard
    However, he managed to correct the tail and head lights (using Menzerna 3.02 & Menzerna Spot Pads as well as the pillars and roof rails so at least that saved me a bit of time on those parts.
    So, with Alan having done his thing with the wash stage and interior it was now my time to flex the muscle of the Makita.
    The paint on this car was rock hard, one of the hardest I've polished in a while so it needed a pretty aggressive combination even by rotary standards.
    John @ PB's Avatar
    Sep 2010
    360
    A 3 stage correction job was carried out using Lake Country Foamed Wool & Menzerna Fast Gloss (not yet in the store but will be very shortly) @ approx 2-2200rpm's then followed up with Lake Country Tangerine H-T pads and Menzerna 3.02 @ 1500rpm's with IPA wipe downs carried out in between.
    The paint would then be further refined by Alan and the DA machine but this was left till the car had been rinsed off after the first 2 stages to get rid of all the dust.
    I suppose I better show some correction shots, in no particular order
    You can just make out a 50/50 line down the bonnet:
    After 3.02:
    The roof had loads of little scuffs and scratches:
    During:
    After:
    O/S front wing, showing the depth of the scratches pretty well:
    And then after the first 2 stages of correction:
    Driver’s door had some pretty obvious sanding marks:
    Under the 3M Sun Gun:
    After correction (3 hits with the wool needed):
    John @ PB's Avatar
    Sep 2010
    360
    N/S rear door before:
    After:
    Under Halogen lighting:
    Under 3M Sun Gun lighting:
    N/S wing before:
    After:
    Rear bumper before:
    After:
    Tailgate before:
    After:
    Side skirt before:
    After:
    Front bumper before:
    This had been resprayed and as a result wasn't so badly scratched so I only needed 3.02 to correct it.
    After:
    Top of rear bumper before:
    After:
    50/50:
    N/S front door before:
    After:
    (Couple of deeper marks left which didn't warrant further clear coat removal)
    John @ PB's Avatar
    Sep 2010
    360
    The approximate level of clear coat removed during the first 2 stages of correction was around the 5-6 micron mark with some places slightly less where only one hit was needed.
    The car was then rolled outside and given a thorough rinse to get rid of all the dust that had made its way into the panel gaps and then dried off again with the Black Baron.
    Alan then got some more polishing practice by refining the finish further with the Das-6, Lake Country Finishing Pad & Menzerna 85RE.
    I then finished off the car by prepping the paint for wax by applying Swissvax Cleaner Fluid a panel at a time before buffing off and then applied Crystal Rock to the entire car and left for 20 mins or so:
    (The carbon fibre parts in the engine bay were done with the same process)
    The front grills were enhanced and protected with Swissvax Protecton:
    Before:
    After:
    John @ PB's Avatar
    Sep 2010
    360
    Swissvax Autobahn was applied by bare hand to the alloys:
    Then all the other minor details were done including polishing and protecting of the door shuts (Werkstat Prime Strong), dressing the tyres (Swissvax Pneu) and conditioning the interior and exterior rubbers with Swissvax Seal Feed:
    One last thing letting the car down were the rusty wheel bolts:
    So these were painted to greatly improve the overall appearance of the car:
    John @ PB's Avatar
    Sep 2010
    360
    And I think that's about it! Here are the finished shots :thumb:....
    Thank you for taking the time to read, if you made it to the end then well done! :D
    Clark
    CHRIS555's Avatar
    DOPE with added OCD
    Jul 2010
    Midlands
    1,941
    Mega - brilliant - love it!
    Ross_S4
    Aug 2009
    Dundee
    718
    Outstanding... as usual!
    Painted wheel bolt heads - REAL attention to details!
    Can I ask, the Swissvax protection, what did you use to work it into the spaces of the grille?
    Dec 2010
    220
    great job ,cant believe the difference
    A3simon's Avatar
    Nov 2006
    Aberdeen
    976
    fantastic cant wait to see mine in may once youve worked your magic on it
    2009 Suzuki GSXR1000K9 SE in White
    2012 Triumph Speed Triple R in Black
    2012 RS3 in Racing Mica Blue
    2012 A1 TFSI in Misano red (shared with mum)
    Bugsy_27's Avatar
    Vorsprung Durch Technik
    Dec 2008
    Everywhere!
    632
    Thats incredible and a massive improvement!
    Audi A3 2.0tdi S Line - Xenons, RNS-E, Bose, Black & Grey duo leather, MY11 rear lights, Shark Performance remap 183 bhp, Optics Grill with American plate delete, S3 Pedals, S3 vents, Weitec Coilovers, MY11 Black Edition FBSW
    Jun 2010
    Coventry/Warwickshire
    2,074
    Amazing work
    Smoothie's Avatar
    Apr 2010
    Lurgan N.I
    1,431
    some of the best work ive seen, the 50/50 on the leather was unreal! i usually use gliptone but might have to change that lol
    Moved to the Darkside click below:
    Iyole's Avatar
    N/A Rools
    Feb 2011
    Cape Town; South Africa
    69
    Stunning !!!..... Well done Guys
    S3RYE's Avatar
    Interior Next!!
    Apr 2009
    London/Essex
    3,456
    amazing job there lads!!!
    Gone but not forgotten......
    S
    3 - Phantom Black - Black Optics - Most Extras
    Mods: Revo Stage 2+ - 18" BBS ch/Michelin PS2 - Recaro OEM Buckets - Milltek TBE NonRes/Sports Cat - Evoms Intake - APR hpfp - H&R Springs/ARBS F&R - Sachs Clutch/Luk DMF - AP Racing 6 Pot BBK - 10mm Spacers - Black Rings
    Mods To Do: Full Retrim - MY11 RNSe - Coilovers- Plenty Carbon
    FranA3's Avatar
    events moderator
    Dec 2008
    south wales
    7,120
    top job there on a top car
    off the road boohoo anyone got a gearbox for me lol!!
    John @ PB's Avatar
    Sep 2010
    360
    Quote Originally Posted by rossbrownlee View Post
    I'll double check with Clark when he's free but I suspect it was a small microfibre pad. Will double check and let you know.
    N8
    N8's Avatar
    Kowalski Details
    Jul 2007
    Salford, Manchester
    17,110
    It was hanging! Great work
    "Will these wheel fit my car PM's will not be replied to, do you research & use the SEARCH button"
    Detailing - Wheel Refurbishment - Shark Performance Software - VagbremTechnic Dealer - OEM Retrofitting - Remus - V-Maxx - Goodridge
    Easty's Avatar
    Mar 2011
    Edinburgh
    Amazing attention to detail
    Drmatrix's Avatar
    Oct 2005
    London,UK
    160
    Lovely work
    Audi A6 2.4 Quattro SE Cashmere Grey
    Audi Allroad 2.5 tdi (180) Quattro Limited Edition Metalic Silver
    Agric04's Avatar
    Feb 2011
    Grantham, Lincolnshire
    198
    Simply amazing, wish I was local so could get my car done.
    The Doctor's Avatar
    Jul 2009
    Planet Earth
    1,175
    I can't believe people who own cars such as these let them get into such a poor state (not saying it's the current owner of course). If I owned that car I'd be loving it more often than I should...! Great job.
