Chris NottMonster Motorsport
Results 1 to 8 of 8
    crazypainter's Avatar
    Jun 2010
    Surrey
    587
    Can I use Menzerna 203S on my headlights?
    Want to give my headlights a bit of a clean up. Seeing if there anything i have in the flat already I can use. I have some Menzerna 203S that i havent cracked open yet but wondering if this is ok or too cutting? Also kicking about i have some Zymol cleaner wax, AG Car glass polish, Meguiars Deep Crystal paint Cleaner. Any of these in combination any good? I should point out I also have the Werkstat Acrylic Kit.
    Need pinstriping? : www.crazypainter.com
    A4.. 1.8T.. Remapped .. Saloon.. Atlas Grey.. Votex Kit..
    S4twiggy's Avatar
    Fully Certified Detailer!!
    Feb 2009
    South Wales
    1,811
    are you using it with a machine i.e DA or rotary?? you can use anything on the headlights to polish up a little but the benefit from using a machine is where you will see the gains but yes yoiu can use 203 on them mate
    Jun 2010
    Surrey
    587
    Elbow grease only !!! Mind you weather has turne a bit ****e so think I will just stick with an interior clean.
    S4twiggy's Avatar
    Feb 2009
    South Wales
    1,811
    like i said mate to get the benefit out of it you need a machine. but go for it and see what you think anyway
    CMD
    CMD's Avatar
    Pointing Forward's!!!!!!!!!
    Nov 2008
    S. Wales
    3,021
    This is the difference when using a Rotary or DA.
    Rear Light example
    BEFORE.
    AFTER
    AUDI A4 190T S-LINE.
    moag's Avatar
    she's no d-turbo
    Sep 2010
    Northern Ireland
    819
    I need to give my headlights some attention aswell. It looks like theres dirt/dust on the inside but surely this can be possible as its a sealed unit? Its not visible in daylight but looks terrible at night. Im hoping its small stone chips that can be removed with the DA
    Jun 2010
    Surrey
    587
    Quote Originally Posted by S4twiggy View Post
    I was under the impression that I could you this polish by hand with a Lake country light cut hand pad. I hope that i can????
    John @ PB's Avatar
    Sep 2010
    360
    Quote Originally Posted by crazypainter View Post
    Yes, this'll be fine: it'll be more difficult than working by machine but if you put in the effort then you'll see good results.
    Polycarbonate headlight covers are generally quite soft and only need polished - there seems to be a trend for wetsanding them but in most cases it's completely unnecessary.
