Badger5JMB Retrofits
Results 1 to 7 of 7
Thread: Lube!!
    phoenixv6quattro's Avatar
    staylowmovefast
    Sep 2009
    wycombe
    1,395
    Lube!!
    Hello gents, just a quick one this time.....Is water a sufficient lube for claying? I usually use a quick detailer but annoys me as its a waste of money as I will use a whole bottle of it when doing the whole of my car. Be great to hear your opinions!
    Ollie
    IT COULD ALWAYS BE WORSE SO KEEP ON SMILING
    jay1601's Avatar
    Jun 2010
    kingsclere
    1,247
    rinse
    wash (2 buckets)
    rinse and while the car is still wet use detailer and clay. i find only use 1/4 the amount compared to dry
    then rinse
    megs step 1
    megs step 2
    chemical guys XXX hardcore paste wax
    thats how i do mine
    Audi A3 8L 1.8T breaking.
    front bumper, impact bar, slam panel, full engine and loom sold.
    everything else for sale.
    staylowmovefast
    Sep 2009
    wycombe
    1,395
    I'de rather not use any QD as lube. Rather leave the car wet and spray water on via a bottle. Need to know if this will suffice. Not a fan of the Megs range. Got blackfire on at the mo.
    1210tech's Avatar
    Four Ring Fanatic
    Nov 2006
    Birmingham, UK
    689
    If you really don't want to use a detail spray then you can get away with making up a weak mix of wash shampoo with water in a spray bottle.
    You do need to use some kind of solution to act as a lubricant rather than just water to help the clay bar slide freely over the surface
    A4 2.5 TDi quattro sport saloon
    RNS-E DVD Nav running SW 0600 with 2007 disc including TMC function, Bluetooth Telephone, Audi iPod Interface
    18" RS6's now gone, replaced by OEM 18" S4 alloys
    Retrofit S-Line Bodykit
    Retrofit OEM Xenon's
    Retrofit Front Ambient Lighting
    Retrofit OEM Aero Wipers (thanks PJMSpeedy)
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,968
    I've all ways used water when claying, never noticed any issues or damage to the paint work.
    The only difference I noticed between water and QD is the smell.
    Is there more to it than just the smell?
    EDIT:=- Added missing words.
    New Car, New Thread: Scott's Akoya Silver A8
    Gone But Not Forgotten: Audrey's Build Thread
    staylowmovefast
    Sep 2009
    wycombe
    1,395
    Excellent! Will try it in the spring!
    Jun 2008
    67
    Weak shampoo mix or use bilt hamber clay, excellent value plus you can use it with water only as a lube!!
