JMB RetrofitsChris Nott
Results 1 to 10 of 10
    John @ PB's Avatar
    Sep 2010
    360
    Polished Bliss®: Audi S3 instrument cluster correction...
    Copied below is a write up Clark put on Detailing World today: thought it'd be of interest to the Audi guys.....
    Thought I'd show you what I was up to this morning as it's a bit different to normal.
    A regular customer of ours with a new S3 was irritated by some scratches on his instrument cluster so it was up to me to see what I could do with it
    First of all this piece of plastic needs pulling towards you and then lifted up (I wasn't planning on doing any pics to begin with hence why the cluster is already removed in these pics :D)
    This then reveals a couple of bolts. Undo these and pull the cluster towards you, pull out the connecter at the back and it pops out quite easily, obviously you need to take care not to scratch the wheel etc:
    The screen was then seperated from the main unit:
    This was put in a bag to stop dust settling on it and I then taped up the screen to prevent any polishing dust getting inside:
    Outer edge masked too to prevent the polisher from burning it:
    Here you can see the scratches in the screen:
    And with the 3M Sun Gun:
    Knowing the plastic was super soft I started with a nice gentle approach - Menzerna 85RE and a Lake Country LSP Spot Pad with the Makita @900/1000rpm's:
    This was slowly worked for a good 3 or 4 minutes and it gave very good results:
    Just a couple of tiny marks left which I gave a second hit, again with 3 or 4 minutes work time at least untill the polish was fully broken down:
    Scratches gone:
    The screen was then carefully wiped clean with some IPA and a brand new Deluxe Mega Towel to remove all the polishing oils:
    Static build up was a nightmare with this thing so I used the Black Baron to blow some light dust out the inside of the screen before putting it back together with the main unit again:
    It was then time to put it back into the dash, starting with the connector at the back:
    Followed by the 2 bolts:
    A quick dust with a Swissvax Detailing Brush...
    Before pushing the plastic trim back into place:
    Quick check to make sure it all works again...
    Total work time: Approx 1 Hour 45 minutes start to finish.
    Thanks for looking!
    S4twiggy's Avatar
    Fully Certified Detailer!!
    Feb 2009
    South Wales
    1,811
    very interesting, didnt know it could be done but i do now so hmmm
    Smoothie's Avatar
    Apr 2010
    Lurgan N.I
    1,431
    Excellent job mate
    Moved to the Darkside click below:
    27,121
    Another excellent job chaps, cant ever have a bad word.
    Whats the tax on this job & can you do this if we were to send the housing to you & return once done, if so then international also possible?
    Clark@Polishedbliss's Avatar
    Professional Detailer
    Feb 2007
    Aberdeen
    228
    Yes if you wanted to send us the housing then we could correct it for you, you'd be looking at around an hours labour (Ł37.50 + VAT) + insured shipping here and back.
    27,121
    The man himself, cheers for info mate.
    CHRIS555's Avatar
    DOPE with added OCD
    Jul 2010
    Midlands
    1,941
    Sweet!
    Mar 2009
    471
    Agreed. Very Nice Work.
    B6 S4 4.2L V8 Cabriolet Black Manual Quad Milltek Non Res
    thelomondaudigroup's Avatar
    Glasgow, United Kingdom, United Kingdom
    270
    Follow thelomondaudigroup On Twitter Add thelomondaudigroup on Facebook Visit thelomondaudigroup's Youtube Channel Visit thelomondaudigroup's Instagram Channel
    Attention to detail is awesome guys, as said one thing I wouldn't ever thought have doing myself!
    JD09's Avatar
    Dec 2009
    Cheshire, Alderley Edge
    3,080
    Exceptional work Clark, had a read of this on DW as well. Has always been an issue with all my second hand cars, so might give this a go when the weather warms up a bit.
