Results 1 to 17 of 17
    S3 Paul's Avatar
    Oct 2006
    2,764
    How to remove snow from the car... Winter is coming !
    Is there a safe way to clear snow from car paint work?
    I was thinking from the weather reports i keep seeing... sooner or later im going to open the curtains and see a white S3 where i parked a blue one the night before
    Noggy Blue 2001 S3
    JD09's Avatar
    Dec 2009
    Cheshire, Alderley Edge
    3,080
    Interesting one, I would warm the car up personally... I understand your concerns though... snow sliding down paintwork, with potential grit in it is not wanted!
    John @ PB's Avatar
    Sep 2010
    360
    A very slick surface should repel snow to a large extent - something like Werkstat Acrylic is very slick. I'd try not to touch the snow unless it's really deep.
    For the glass and headlights, a top quality glass sealant like Nanolex Premium Nanolex Premium Glass Sealant | Nanolex Car Care & Detailing Products or Urban Nanolex Urban Glass Sealant | Nanolex Car Care & Detailing Products will help stop frost bonding and also prevent snow building up.
    (We had some snow here last week. Not quite the 4ft we had last winter yet though.....)
    Fahim's Avatar
    Dec 2009
    Wanstead
    280
    Why not just buy a car cover if your so worried about the snow?
    Things to do: Lower on coilovers, spacers, front end respray and a full correctional detail!
    John @ PB's Avatar
    Sep 2010
    360
    Quote Originally Posted by Fahim View Post
    Probably because they'll cover the car in scratches.....
    If the car isn't spotless when a cover's applied, or if the cover isn't spotless on the inside, as you move the cover over the paint, it'll scratch the paint.
    JD09's Avatar
    Dec 2009
    3,080
    Quote Originally Posted by John @ PB View Post
    Regardless of cleanliness, 99% of car covers will scratch due to what they're made of as well! Had this experience after wanting to protect the car over a two week holiday (bird droppings etc). Came back to a car needing faint correction again.
    Not happy.
    John @ PB's Avatar
    Sep 2010
    360
    Quote Originally Posted by JD09 View Post
    Not happy.
    Not good at all.
    My post was based on non-experience: I've never used a cover. And never intend to! Your post has confirmed that even further.
    beanoir's Avatar
    Sharpest Tongue in the West
    Jan 2007
    51 Degrees North
    2,173
    Snow must be cleared from a car before driving it anywhere as it's a danger to other road users when iced up clods of it fly of your car at 50mph into their windscreen.
    Why not justy pour warm water over the car, I mean luke warm, avoiding pouring directly onto glass and you'll be fine. Couple this with heating on in the car to ensure that windows don't re-ice. Works for me and has done for years.
    Porsche Cayman S |Jeep Grand Cherokee|1988 Ford Fiesta XR2
    www.essexdriversclub.com
    HerefordQuattro's Avatar
    Hereford
    303
    personally use a dustpan (with rubber lip) to shovel the wind screen clear but obviously not the paintwork, after a slow crawl down the road most loose stuff will fall off as you gather speed (if you can)
    A6 Avant 2.5tdi Quattro Sport 220bhp 458Nm 6 speed Manual
    Aug 2009
    833
    I used to put a towel on the windscreen, get out lift off and away you go.
    Fahim's Avatar
    Dec 2009
    Wanstead
    280
    Wouldn't that just cave in under snow?
    Doesen't look sturdy enough to withstand a bit of snow, but going in the right direction i suppose.
    FranA3's Avatar
    events moderator
    Dec 2008
    south wales
    7,124
    i would say the best way is to try and keep your car clean so if the snow does slip down the paint its got less chance of scratching it , what i did last year was to warm the car up
    ​She is back on the road yay!!
    flat out
    north weald essex
    220
    usually i clear the snow almost down to the surface by hand then pour warm water on all windows etc to clear the rest.
    to be honest though if there is a lot of snow i call in snowed in and go back to bed!
    May 2010
    274
    tbh the water doesnt need to be all that warm! just straight from the tap does it for me!
    I used to not really care with my Corsa/106 and just push/slide it all off.. but i've been paying special attn. to my A3 now and wouldn't dare!
    8P Audi A3 2.0TDI Quattro Sport - what a change from my 1.0L CorsaC!!!
    follow me on Twitter - Jonay1990 for #Photography #Aviation #Mil #Automotive #Subsea
    Nov 2010
    Stornoway, Scotland
    68
    i have a small portable heater, like a mini space heater, set it to a gentle heat and it clears snow in seconds. i also have a bar heater specifically to leave under the car to warm the engine before starting it in sub zero temperatures.
    pi quattro's Avatar
    Oct 2009
    Ayrshire
    127
    i drive fast, it blows off, stop hard and it falls off. then i call my mate and ask him if he wants my quattro to pull his 5 series off his driveway!!! Ha Ha
    current -
    07 A3 TDI 170 quattro
    rnse,leather,auto lights & mirrors,bose,sunroof,xenons, etc
    previous-
    06 A3 2.0TDI sport quattro - rolled & gone
    06 A3 2.0T sportback dsg leather - gone
    06 A3 2.0TDI sport -gone
    01 1.8T GTI -gone
    01 A4 TDI 130 - gone
