AH FabricationsChris Nott
Results 1 to 12 of 12
Thread: Snow foam....
    Wozski's Avatar
    480
    Snow foam....
    Apologies for my inexperience, can you use snow foam with pressure washers that have the detergent hose outlet??
    Can you recommend any?
    cheers
    James.Asbri's Avatar
    Vorsprung Durch Technik
    Snake Champion
    Aug 2009
    Cardiff
    1,181
    You can yes, no detergent will be released if the power wash is on it's maximum pressure!
    MY11 Audi A3 Black Edition | Ibis White
    Technology Pack | Interior Light Pack | Heated Front Seats | Tyre Pressure Monitor | Folding Mirrors | Deletion of Model & Engine Capacity
    Follow me on Twitter
    Wozski's Avatar
    480
    How do you use the snow foam then?
    JD09's Avatar
    Dec 2009
    Cheshire, Alderley Edge
    3,080
    To be honest, these aren't very useful. You're are much better buying a specific snow lance. For circa 45 they are very much worth it!
    To give you an idea from playing with a few in my time, the first two images are from what you have mentioned, or cheaper foam bottle attachments (note the lack of actual foam, rather soapy water). The last photo is from an I4Detailing lance found here; Snow Foam Lance - for use with your pressure washer - various fittings available
    Sarah's A3's Avatar
    MODERATOR V6 S3 Hybrid
    Cheshire to Perth AU
    5,923
    I've been wondering about this, ours always looks like pic1!!!! Cheers James, will be following your link.
    JD09's Avatar
    Dec 2009
    3,080
    No worries Sarah.
    Jun 2007
    Yorkshire
    307
    Seconded, I had the first type and it was useless.
    Bought a proper snow foam lance from cleanyoucar and the snow foam is excellent, very effective wash for a non-contact wash.
    Ibis white 2010 A3 2.0TDI Black Edn.
    John @ PB's Avatar
    Sep 2010
    360
    We do a foam lance kit which includes Meguiar's Hyper Wash: with a dilution ratio of 400:1 (water/product) it's the most concentrated we've found.
    PB Foam Lance Kit
    I worked out the price recently, including shipping, of Hyper Wash and found each litre of foam solution costs 0.025 pence per litre
    Compare that against some of the apparently cheaper foams and they don't appear so cheap.....
    JD09's Avatar
    Dec 2009
    3,080
    Agree on the Megs Hyper Wash being a good buy, but hadn't quite worked out the costs! Love that you have John
    John @ PB's Avatar
    Sep 2010
    360
    Well, it's one of those things! On A.N Other forum, a user suggested a different type of snow foam and also suggested Megs Hyper Wash was expensive. T'other foam has a dilution of 25:1 or 15:1. Basing on 25:1 its cost per litre is 0.247 ppl. (10x the cost of Hyper Wash). So the 'expensive' Megs Hyper Wash suddenly looks a lot more appealing!
    JD09's Avatar
    Dec 2009
    3,080
    John, out of interest, have you noticed a distinct advantage between a lower pressure rated washer and a higher version? My snow foam, until recently, always came out well, but never shaving foam consitency. But since upgrading the old unit to a newer, more powerful version, the snow foam is distinctly thicker...
    John @ PB's Avatar
    Sep 2010
    360
    yes, generally speaking, the higher the pressure the thicker the foam.
    pressure, as opposed to flow, is the key factor.
