EM TuningMonster Motorsport
Results 1 to 10 of 10
    Jimmeh's Avatar
    Mar 2006
    East Midlands
    1,426
    Add Jimmeh on Facebook
    Audi A4 2.0T Quattro
    Hi all - there hasn't been much worth documenting recently; just my maintenance jobs and small Protection Details.
    Thought this one might be of interest though..
    Audi A4 b7 2.0T Quattro
    I was contacted a while back now for this one. Main area of concern was the mass amount of paint spots that had found their way onto the Audis bodywork Possible White Line markings from a freshly laid road?!
    21 hours spent here over three days.
    Product
    3M FastCut+
    3M Glass Cleaner
    AutoSol
    AutoGlym Vinyl and Rubber Care
    AutoSmart Tardis
    AutoSmart G101
    Blackfire All Paint Protection
    Chemical Guys JetSEAL109
    Dodo Juice Born To Be Mild
    Elite Fine Grade Poly Clay
    Elite Medium Grade Poly Clay
    Jeffs Werkstat Prime
    Menzerna 203s
    Menzerna 85RD 3.02
    Meguiars Endurance Tyre Gel
    ONR
    Inspection:
    Some nasty scratches to look at:
    Interior already nice and tidy; just requires a wipe around and a hoover:
    Engine-bay ready for a good clean:
    First off, the wheels were hit with a pretty strong Wheel Brightener mix. In an ideal world (and as far as I understand they will be soon) all four wheels would be refurbed. Only visual let down for this car as it stands.
    Once fully washed and de-tarred, it was time to take a look at those Paint specs.
    Although Elites Fine Grade Clay Bar removed surface contaminants, it barely touched the paint.
    Literally the whole car was covered. Even spotted bits on the roof line!
    Stepping up to a Medium Grade Clay Bar seemed to help. Very tedious and time consuming! (but, it was doing the job) 2 litres of ONR mix was used here as a lube. Of course, the downside of an aggressive clay bar is the way it can mar the paint. Sure enough, it did!
    Once inside, dried and taped up, polish and pad tests were carried out on the bonnet.
    But up close you can see a fair bit was left (lots of random deeper scratches)
    I was hoping to polish/refine the car in a single hit. However, Id been asked to pay particular attention to the deep marks so multiple passes would be needed after all.
    With this in mind, Menz 85RD 3.02 was used on a light cutting pad but still, room for improvement. Breaking out Fast Cut+ gave near 100% correction first time. Some areas required a second or third hit but some others were left at the one (thinner paint on the N/S rear quarter and tailgate)
    Before:
    After:
    Before:
    50/50:
    Before:
    After:
    Before:
    After:
    Progress was good. A heavy cut spot pad was used for the tighter spots and a 3M Cutting Pad used for the larger open areas.
    As each panel was selectively worked, refinement followed soon after with Menz 203s on a light cut pad.
    N/S edge of the roof line looking good:
    Some sill work with the spot pads:
    Bonnet before, afters and 50/50s:
    Audi A4 Avant 1.9TDi 130 Quattro Sport.
    WhiteDetails.co.uk - Facebook? Follow me!
    Jimmeh's Avatar
    Mar 2006
    East Midlands
    1,426
    Initial polish and pad tests were carried out on the bonnet with a light cut pad and Menz 203s. This area was hit again with the heavy cut approach and further refined later in the day.
    Finishing off for Day 1, I made a start to the boot lid. (Paint readings throughout were pushing the 140 mark which made a nice change. The boot and O/S rear quarter however were down to the 90’s in places. Because of this only as single cut/refine approach was given)
    Before:
    After:
    Before:
    After:
    Day 2, 9am… Back to work.
    The top quarter of the doors were hit as one with spot pads. Two passes whilst cutting and a third refinement stage given.
    (See what I mean about the clay marring?)
    Tight areas around the handle were hit first with spot pads. The rest of the door received the 3M Cut Pad.
    O/S rear door with the scratch that was photographed at the start of this report.
    After the first hit:
    But up close under intense light it’s still there:
    With paint to play with, a further second pass was made:
    Much better.
    Working down onto the rest of the door:
    And then back higher up on the small pad work:
    Menz 203s residues ready to be removed after minutes of burnishing:
    Et voila:
    The rest of the bonnet was finalised:
    Jimmeh's Avatar
    Mar 2006
    East Midlands
    1,426
    Nasty bird etching on the N/S edge:
    Machine work coming to an end... 9 hours solid on the second day.
    Bumpers, mirrors, B & C-Pillars and light clusters remain.
    A bit of a miss match on the colour here no?
    And bringing Day 2 to an end, the engine bay was dressed.
    The morning after and of course, we have polishing dust:
    After a thorough pressure wash of all shuts/crevices/sills/joins and gaps, water was sheeted over the panels and then pat dried.
    Back inside, blown bone dry with the Black Baron Vehicle Dryer and then wiped with AutoPerfection’s IPA.
    Paintwork looks amazing already. Time however for Blackfire:
    Britework attended to with Jeffs Prime:
    Alloys sealed with JetSEAL109. Tyres with Endurance Gel. Glass with 3M’s Glass Cleaner:
    A quick wipe, tickle and tidy of the interior and its time to chase the sun.
    Jimmeh's Avatar
    Mar 2006
    East Midlands
    1,426
    Here you can still see the deep bits on the boot lid:
    Engine before and afters:
    A most enjoyable 2.5 days spent here on this one. A very nice (well spec’d!) car and a massive transformation.
    Thanks for reading.
    Jim
    Sarah's A3's Avatar
    MODERATOR V6 S3 Hybrid
    Cheshire to Perth AU
    5,923
    Hey Jim, another brilliant job done! And no dog to slow you down this time lol! The pillars look good after youve worked on them. The popping is great! Well done matey
    Ash B's Avatar
    Jul 2008
    Cardiff
    5,808
    Great work and write up as always Jim. Keep up the good work
    Dark Vader Half sibling - MyThread
    Nilz's Avatar
    Defo worth the wait :)
    Apr 2006
    10,096
    Well done mate, another grand job by Jimbo
    Mr.G's Avatar
    Nov 2008
    In a Tardis!!
    1,302
    Jim, as always mate S T U N N I N G. Really really good 2 days detail there, well done owner must be over the moon with it.
    G
    Ross_S4
    Aug 2009
    Dundee
    718
    Those are some truly stunning results!!
    Can I ask, what did you use to tidy up the black plastic trims on the rear door windows?
    CHRIS555's Avatar
    DOPE with added OCD
    Jul 2010
    Midlands
    1,941
    Fantastic - really really impressed mate
    Best wishes
    Chris
