Sky InsuranceEM Tuning
    mcconnot's Avatar
    Sep 2009
    75
    Headlight problem
    Hi Guys,
    Ok minor problem (i hope). Had my first stab at polishing my A3 with a rotary the other day. Results were great as the car shines now. However, when i decided just to run a wool bonnet gently over the headlight casing just to buff it up. When i was on the left head light the wool bonnet slipped on the rotary (ie- the velcro slipped) and the edge of the hard velcro backing plate scratched the light. It looks like an abrasion.
    Question is can i somehow polish this out of the plastic light casing?? Its not that deep at all.
    Cheers for any help!
    Tom
    Mar 2010
    Bristol
    48
    i've seen alot of people wetsanding the light, then usethe rotary to polish it back. really does depend on how deep it is though.
    hope that helps
    mcconnot's Avatar
    Sep 2009
    75
    Cheers man! No its not deep because i pulled away as soon as i seen it start to happen. The surface is just gone rough- it looks like it would polish out again. Hopefully!
    Mar 2010
    Bristol
    48
    no worries.
    if it's only roughed up, you might get away with somelike 3000 or 4000, which would make the polishing out much easier.
    i need to do something similar to mine as got loads of stone chips on my headlights and i hate it!
    hope it works out well!
    Ian W's Avatar
    Oct 2007
    Wirral, Merseyside
    1,054
    I polished mine up the other day, 1500 then polished with my DA.
    Took off alot of crap from the headlight, didn't want to go to far with it though, certainly worth you having a go at flatting and polishing it out.
    John @ PB's Avatar
    Sep 2010
    360
    I'd start with a less aggresive combination than a wet sand: something like a Menzerna orange pad and Menzerna 3.02 polish should be sufficient. I'd suggest trying this first but keep an eye on temperatures.
