Monster MotorsportChris Nott
Results 1 to 1 of 1
    brasiliangringo's Avatar
    Mar 2010
    496
    1.8T APU engine, faultless condition - £325 ono
    This is for a complete engineincluding turbo.
    Engine and turbo running faultlessly with exception of requiring a new coolant temperature sensor (the only code on VCDS after extensive test drive) and will also need a cambelt change.
    I have measured boost output using Ross tech VCDS and the actual boost matches the specified values with unbelievable accuracy (chart available here) as is the MAF peak value at 126 g/s so very nearly bang on 120 g/s where it should be. Engine available to see running whilst car is still in tact.
    Audi part numbers :
    058 103 101 H - CYLINDER BLOCK WITH PISTONS
    058 103 265 FX - CYLINDER HEAD WITH VALVES AND CAMSHAFT
    058 145 703 J - K03 TURBO FOR APU ENGINE
    Would prefer collection and DIY dismantling.
    £325 ono. Near Southampton area, Hampshire.
