Sky InsuranceBadger5
    Jul 2003
    Re: TopGear - M3 v S4
    Just found it! Thanks anyway.
    imported_exxy
    steering rack removal
    Replacing the pas rack on audi 80 2.0 auto 93 year. it looks like i have to pull the column back to remove the spline end of the rack
    Which bolts on the column need to be undone>?
    or is there another way around this?
    many thanks
    audi5e's Avatar
    Jun 2004
    Johannesburg, South Africa
    809
    Re: steering rack removal
    on the 100, you just undo the bolt connecting the column universal joint to the rack then pull the rack into the engine bay to remove it.
