Monster MotorsportEM Tuning
Thread: 89 quattro 200
    imported_kingsaudi
    89 quattro 200
    Hello everyone, pardon my ignorance, I'm a newbie to audi's, but I will learn !!
    Bad hydraulic fluid leak, replaced leaking pump to resevoir hose, but still leaks- in fact I see a lot of fluid all over the top of the resevoir. (the hose was from a junk yard, I know ! I'M BROKE)
    Anyway, how can I see exactly what and where the leak(s) are coming from, should I have a frien step on the clutch ? any help much appreciated
    By the way the symptom is the clutch sticks to the floor
    Thanx
    audi5e's Avatar
    Jun 2004
    Johannesburg, South Africa
    809
    Re: 89 quattro 200
    try giving the engine (and all pipes) a good clean, then press the clutch pedal, you should be able to see where the leaks are.
