Sky InsuranceChris Nott
Results 1 to 19 of 19
    imported_WannaBFast
    86\' audi 5000cs turbo quattro
    is it worth it? its 5spd, awd, turbo, abs, 4wheel disk
    is there any aftermarket parts? if so where
    and ill probablly pick it up since its in near immaculate condition... LMK
    oh.. ive driven this particular one a few years back... never opened the throttle all the way... but has been hidden away in my dad's garage for the last 5-6 years [img]/ubbthreads/images/graemlins/groovy.gif[/img]
    audi5e's Avatar
    Jun 2004
    Johannesburg, South Africa
    809
    Re: 86\' audi 5000cs turbo quattro
    read the post on the 88 CS. you will get an idea of what can go wrong with them. advice to you is check that the car has a service history. even better if it is from the agents. you can then contact the agents and see if they have any problems on file for that specific car.
    audi5e's Avatar
    Jun 2004
    809
    i gather you are the best person here to know if your dad drove the car hard or not.
    imported_WannaBFast
    well my dad is a master mechanic that owns his own shop.. so if there are any problems with it whatsoever.. he would know.. he says it runs great.. im gonna drive it tonight... ill keep you posted...
    does anyone know how much boost that particular motor can handle?
    audi5e's Avatar
    Jun 2004
    809
    how much boost can YOU handle? and your pocket? :-)
    just remember if you carry on boosting you are just going to end up losing reliability.
    audi5e's Avatar
    Jun 2004
    809
    also remember that time you took dad's car out for the joyride..... revvvengggggge! :-)
    imported_WannaBFast
    update: my dad handed me the keys to the car.. in all its glory... the brakes just need to be replaced, and rotors need to be turned.. other than that.. i see a interesting rally project in the mix.. altho i think it might be a tad to big for rally.. well then.. drifting it is
    imported_WannaBFast
    oh.. and my other car is a civic.. so reliability isnt really an issue right now
    imported_WannaBFast
    ok.. now after doing some research.. it looks like the audi 200 from 91 has almost the same motor.. except that its DOHC.. would it be fesible to swap? or are there too much extra electronics involved?
    audi5e's Avatar
    Jun 2004
    809
    not sure about that? you probably find they used completely different control systems. I would imagine the multivavle version would need a more complex management system to handle the extra fuel/air/boost. I am not sure when audi started it, but i know more modern engines use variable vavle timing, with ecu control.
    is your civic the old 1.6 vtec version with the lift around 7000rpm ?(we used to have one here with an output of 118kw)
    imported_WannaBFast
    actually its a 2001 with some goodies... its a 1.7L with vtec-e which has 1 intake valve until the vtec engages... its for fuel economy... it put out about 118hp a while back... its tuned to the t.. and its still slow..
    so.. its too nice to drive all the time... yea i know its a friggin civic... but the audi will become my daily driver
    audi5e's Avatar
    Jun 2004
    809
    the vtec we had here in the late 90's had a 16valve unit, once it hit around 6800/7000 rpm it would pull the inlet cam across onto a higher lobe also longer duration... hold that all the way through to 8200rpm... Toyota Corolla had a similar engine also reved through to 8200rpm, but was a 20valve unit with variable vavle timing... for some reason we were the only country in the world at that time to have the 4AGE 20valve motor in the corolla (the europeans had it in a much bigger car)... probably because we are all a bunch of maniac drivers... :-)
    the corolla had longer gearing than the vtec and would hit its peak torque around 5000rpm so it had a very long power band compared to the vtec. both makes were very reliable. when I sold mine it had 187000km's on it and all the dealers were telling me the motor was still tight! (i hate to think how other guys drove their cars....)
    imported_WannaBFast
    hahaha yea.. you are probablly thinking of teh DOHC VTEC... the SOHC vtec only revs up to 6800...
    the sohc vtec hondas only changed the intake duration and lift, as opposed to the dohc where they would change both intake and exhaust valves... the one in my civic just opens the second intake valve... i have 16valves so 2 exhaust all the time, but 1 valve during the lower rpms, and switches over around 3k
    hey does anyone know if this one has a blow off valve or soemthing? i have yet to fool around with it
    audi5e's Avatar
    Jun 2004
    809
    no idea, you will have to ask in honda forum on that one. unless someone here happens to know... :-)
    imported_WannaBFast
    was referring to the audi... hehe
    audi5e's Avatar
    Jun 2004
    809
    what they do is specially design the metal to dramatically self destruct.... seriously, i am not sure.
    imported_WannaBFast
    does anyone happen to know what kinda brake fluid it uses? is it DOT 3 or DOT 4? the calipers are seized, so im getting rebuilt ones all around.. cause the parking brake doesnt work
    imported_WannaBFast
    ok, found out that it uses DOT4 brake fluid..
    now.. does anyone know if theres a short shifter kit for my audi?
    oh.. and heres my plans as of now...
    new radiator(bead is not there anymore so it wont hold a hose on there... ending up in coolant loss...
    and the calipers need to be replaced i think... but after maintainace stuff gets finished.. im gonna get bilstein shocks and h&r springs
    Jan 2005
    in response to the blow off valve question i was also wondering.. i called dealerships and a performance auto place and both places said because it uses the internal wastegate you cannot run a blow off valve, which kind of confused me because i know the 1.8t vw's use an internal wastegate but can still use BOV's.. anyone have any idea why this is or know for sure if you can or cannot use a blow off valve or diverter valve without somehow disabling the wastegate
