I
imported_stephens_aj
Audi 80 1993 2.0l Erratic Idle... Help???
Hello,
Got an intermittent idle speed problem. I experience this once every couple of days. The typical symptoms are: when driving I'd pull up to a set of lights, instead of the engine dropping its revs back down to 900-1000rpm, the idle wavers between 2000 & 3000 rpm. The only way to temporarily correct the fault is to switch the ignition off for a couple of seconds, re-start and everything is then fine again!?
Has anyone experienced the same or know where I might start to correct the fault?
Any help greatly appreciated.
Cheers.....
Hello,
Cheers.....
