    imported_norad97
    Audi 80 2.0 Sport Saloon (Temp high)
    Hi,
    I have had an Audi 80 2.0 Sport Saloon 1990 for 7 years, 118.000 miles,
    Have had no problems.
    Now when I am in Traffic the temp gauge reaches the middle the water light flashes
    on the dash, the fan works fine and is cooling the car.
    I have changed the sensor for the fan and the sensor that is a part of engine management system.
    The only parts left to change are, Temprature sensor/sender(the one that operates the temp gauge on dash) or water bottle sensor.
    any help please,
    Regards,
    Richard
    imported_norad97
    Re: Audi 80 2.0 Sport Saloon (Temp high)
    Sorry I forgot to say its 1990 model.
    It only gives out numbers as fault code, not like the later
    models the have better readout from the computer.
    You think it could be the temp sender?
    I was told it was more just a temp sender but not sure?
    The light on the dash means low water or overheat.
    Richard
    audi5e's Avatar
    Jun 2004
    Johannesburg, South Africa
    809
    if you want the codes i send them to you?
    one of the codes gives the engine temp...
    press the recirc button and the window direction arrow to enter the diagnostics then use the temp minus button to go to 51, once 51 is selected press the recirc button again and it will display the current engine temp. that way you can check if the engine is running hot. does you car have a temperature gauge in addition to the lamp?
    imported_norad97
    Yes it has temp gauge, when the gauge reaches the middle ( i.e. pionts to 12 O clock)
    the light on the dash starts flashing.
    This is the same lamp that tells you you have low water in expantion bottle,
    also i read in the book it also shows overheat.
    The fan operates correctly so the car is not overheating but i do not no the cure to this fault,
    its just bloody geting to me now, everytime the light is on!!!!!!!
    audi5e's Avatar
    Jun 2004
    809
    well i guess you will just have to check the sender units for both the expansion bottle and the guage/lamp.
    imported_norad97
    I have just fixed the problem!
    I have purchased a new temperature sender from Audi.(the one that sends to the Gauge).
    You see the car was getting to hot, the gauge was not reading correctly.
    [img]/ubbthreads/images/graemlins/groovy.gif[/img]
