Revo TechnikDTUK
    Oct 2008
    Post Thanks / Like
    starting problem
    any info would be helpfull.audi coupe 2.3 k reg 93, started fine on morning drove to petrol garage 2 min drive stopped then went to start again nothing, upon turning the key with the bonnet up yuo here a double clicking sound not very load and thats all.the car started again when bumped but when turned off and then on again you get nothing except 2 clicking sounds.is this a starter motor prob? where abouts is the starter located? any help would be extremly good.thanks
    Rev-head's Avatar
    Oct 2004
    Perthshire
    2,948
    Post Thanks / Like
    I take it you started the car by bumping it ...sounds like starter is jammed ..check to make sure you ignition switch is not sticking on(should be recoiling) and burning out starter
    Urq RR
    S2 Coupe...RS2 +
    S2 Avant (slipper wagon spec)
    A4 AVANT TDI
    audi5e's Avatar
    Jun 2004
    Johannesburg, South Africa
    809
    Post Thanks / Like
    Those clicks sound like the starter solenoid trying to work but not enough to engage. Could be the solenoid, could also be the battery or associated wiring harnesses.
    Bird watching freaks of the world unite at:
    http://www.simplybirding.com
    Even the RSPB would be afraid...
