Backdraft MotorsportSky Insurance
    Mar 2007
    DORSET
    14
    Post Thanks / Like
    Audi cabriolet Hydraulic fluid Resovoir in boot (electric rooF)
    AUDI CABRIOLET 1993 L REG.
    My electric roof has stopped working
    1) release T bar handle
    2) windows go down as they should
    3)press roof opening button, roof starts to open but storage cover which should lift , only LIFTs up by 4 inches then stops.
    I have checked wire looms all ok !
    I checked the Hydraulic fluid level in the resovoir of the roof opening system in the boot ... and it is well below the minium level.
    What type of Hydraulic fluid do i use to top it up ?
    I have been told that it is the same fluid as the POWER STEERING FLUID IS THIS CORRECT ?
    PLEASE HELP
    Mar 2009
    Post Thanks / Like
    I have the same problem with a 'P' reg, where is the reservoir?
    NineNails's Avatar
    Proud sponsor of the snack food industry
    Sep 2006
    North Wales
    421
    Post Thanks / Like
    You'll find lots of info over on www.audifans.net in the cab section of the forums.
    Si.
    2000 1.8t quattro Sport totally standard (ish)
