im interest in what happened to mike myres problem and what was end result i have no spark at the main coil lead new coil and module fitted fuel getting through just dont know what else any help thanks
Which engine do you have? Checking the ECU for fault codes should point you in the right direction if it is a component that has failed.
I would try testing the hall sender if you can't get the codes checked?
