Volks AutosAH Fabrications
    Partyboy's Avatar
    Apr 2007
    Northampton
    Audi Cabriolet fans allways running!!!
    Not long had my Audi Cabriolet 2.0 8v i have a problem in as soon as the ignition is switched on the fans run constant!!only stop when switched off!!Has anyone got any ideas??is it a common problem??cheers people!!
    Rev-head's Avatar
    Oct 2004
    Perthshire
    2,955
    the fan switch wires has been crossed over so the minute you put on ignition this will happen need to follow wiring from fan down to switch .probably needs new switch
    Urq RR
    S2 Coupe...RS2 +
    S2 Avant (slipper wagon spec)
    A4 AVANT TDI
