Chris NottAH Fabrications
    May 2006
    cumbria UK
    Please help my audi is sick
    Hi im looking for some advice on my audi coupe v6, i was driving along the other nite and then i lost all power, died out. its turning over fine but i dnt think is getting fuel, i changed the fuel filter and also checked the pump any one have any ideas, will be greatly appreciated. the fuel pipe that leads to the engine in the bay i have slackend that off and no fuel had got there. cheers.
    Rev-head's Avatar
    Oct 2004
    Perthshire
    2,955
    Fuel pump relay?
    Urq RR
    S2 Coupe...RS2 +
    S2 Avant (slipper wagon spec)
    A4 AVANT TDI
    atc
    Nov 2005
    Essex, UK
    105
    You should be able to hear the fuel pump prime when you turn the ignition on (postion 2 when all the dash lights come on) If you can't hear it hum (1-2 seconds only) then Rev-head is probably right. If you can hear it hum but still no fuel it could be the lift pump.
    May 2006
    cumbria UK
    got it sorted in the end was the fuel pump playing up, got a nasty bill of 140 for a new one. cheers
