Chris NottVolks Autos
    smogthemog's Avatar
    Oct 2006
    South Lincs
    41
    URS6 or even A6 AirCon wiring diagrams/help ?
    URS6 or even A6 AirCon wiring diagrams ?
    I have a problem with my AC on my 97 (4A) S6 Q Avant.
    There is no +ve (black cable with a red stripe, when you take out the relay socket) to the AC clutch relay (pin 30) in the under bonnet fuse box (in the top left corner of the engine bay).
    I have no AC pump clutch operation either when the car is operating normally or when hooked up to VAG-COM (registered) and in the HVAC output test mode. The AC clutch relay operates fine but there is just NO 12v feed to it to be switched by it, to the AC clutch.
    If I scource a 12v+ feed from somewhere else the clutch operates perfectly and the cabin air get's cold (darn cold ), it just seems to have lost the 12v feed to the relay ???
    Has anyone got a diagram or can tell be exactly where this relay gets it's power from ?
    All fuses I can find seem ok.
    I had a 94 A6 2.8 Q A before the S6 and the HVAC system was exactly yhe same so I presume the wiring diags are the same.
    Anyone got Mitchell ???
    Jim
    Jim B
    97 S6 Quattro Avant 4A AAN | Powerflow Cat Back EX | Milltek Hyperboost RV | FMIC | Washer fluid level indicator | Emerald green | HID's | MRC re-map 290BHP | Carbon interior | De-Chromed | Red Stuff's | Retro Wipers |
    My 'other' hobbies
    www.liquidskylasers.co.uk
    http://smogthemog.blogspot.com/
    Mar 2005
    uk scotland
    13
    aircon
    send me your email address
    power comes from f11 to d8
    Rev-head's Avatar
    Oct 2004
    Perthshire
    2,955
    He got wiring diaghrams on S2forum from Jas
    Urq RR
    S2 Coupe...RS2 +
    S2 Avant (slipper wagon spec)
    A4 AVANT TDI
