Thread: advice needed
    phillH's Avatar
    Jan 2007
    chester
    7
    advice needed
    Hi all,
    I am the proud owner of a very mint 1995 coupe 2.6
    i'm about to lower it 40mm and replace all the bushes with a powerflex kit and add some anti roll bars,
    but it just aint fast enough.
    i know tuning options are quite limited on the v6, but does anyone have any suggestions to get a bit more bhp.
    im planning to get a new exhaust system not sure which one and an induction kit. i hear remapping the ecu wont do much.
    so how can i get the power up (without replacing the engine or spending a fortune)
    thanks all
    Rev-head's Avatar
    Oct 2004
    Perthshire
    2,955
    Hello and welcome to the site
    There is not that much you can do apart from what you are doing now....If you were to spend a few quid getting the inlet manifold ports polished would help as they are never well done ....there is a way were you can open the throttle body up a bit further but not sure on the detail on that .....If you go onto www.034motorsport.com sure there is a few things listed there for your motor
    Urq RR
    S2 Coupe...RS2 +
    S2 Avant (slipper wagon spec)
    A4 AVANT TDI
    phillH's Avatar
    Jan 2007
    chester
    7
    thanks for the welcome and the info buddy
    May 2006
    cumbria UK
    Hi i have a v6 coupe too, i have a full stainless steel remus system on mine, sounds awsume. i removed the cat aswell to get the extra grunt and torque. i also have a ram air induction kit. fse do a boost valve that they say will give you aprox 12 bhp on standard boost and could knock at least half a second off to 60 although i am unsure about these figures. With filter and exhaust on, a rolling road tune up could be a good idea, could add more bhp.
    please let me know how you find the suspension i am also looking to up grade.
    phillH's Avatar
    Jan 2007
    chester
    7
    will do thanks
    28v6
    Pull the engine, rebore it out to a 3litre balance and Blue print it, Port & polish it, then Big valve her...you should see around 40 - 60 horses not alot I know.. but its better than nowt and she'll be smoother on the pick up...
