    Oct 2006
    newbie....name the part...
    Can anyone varify that this is the idle stabalizer valve from the picture below. It is located to the right of the air duct and right between the turbocharger and windshield washer fluid container. In one end it has a harness connection and the other is connected to a hose that looks like it leads to the turbo. When I turn on the power to the car (not start) it gives a buzz and i am not sure if this is good or not. So if anyone can varify that this is the idle stabzlizer valve and if a buzzing is good or bad taht would be great. Thanks
    http://i119.photobucket.com/albums/o...knownpart1.jpg
    Rev-head's Avatar
    Oct 2004
    Perthshire
    2,955
    very dodgie picture could you take from further out ..were you say it is positioned sounds like ISV
    Urq RR
    S2 Coupe...RS2 +
    S2 Avant (slipper wagon spec)
    A4 AVANT TDI
    28v6
    I'd have to agree there Steve on both counts a dodgy photo indeed, but yes it is the ISV...
    However, on what car though... usually the ISV is on the opposite side from the water resevoir...So I'd like to see a bit more...
    dummi's Avatar
    smoking a6
    Mar 2004
    brumingham
    1,188
    if it is connected to the turbo it is like the n75 waste gate control solenoid.
    which car is it, so we can eliminate the possibilities further...
    just a little a6
    Oct 2006
    info
    its an 87' 5000cs Turbo Quattro
    28v6
    200 Turbo quattro Guys!
    Yep, then its the Idle Stabilization Valve (ISV)
    and yes a "buzz" or "hum" off the valve is good as it means that the valve is working.. although possibly on its way out. The valve should be silent when new and as it grows older may start to buzz.. so long as the Idle is still working and steady. Take the valve off completely and clean with Carb cleaner until spotless, then lube with some 3in1 oil and work the trap door, then replace...
