convertible top lock
gasket
- 155871431 gasket
1 8G0871025 top frame
for vehicles with mechanical top operation
(1) 8G0871025C top frame
for vehicles with hydraulic top operation
2 8G0871107G spacer plate / 0,5MM
/ front
3 8G0871107H spacer plate / 0,5MM
/ rear
4 --------- no longer available
F >> 8G-R-009 000*
5 N 01100830 hexagonal nut / M8
F >> 8G-R-009 000*
5 N 90908301 shouldered hex. nut, self-locking / M8
F 8G-R-009 001>>*
6 N 01024022 bolt, hexagon head self-locking / M8X20MK
F >> 8G-R-009 000*
6 N 0197002 hexagon head bolt c/w shoulder / M8X30
F 8G-R-009 001>>*
7 8G0845353F gasket / front
8 8G0871497C retaining strip / front
9 N 0139575 oval head panel screw / B3,5X9,5
10 8G0845423B reinforcement rail / left front
(10) 8G0845424B reinforcement rail / right front
11 8G0845429F gasket / left, center
(11) 8G0845430F gasket / right, center
12 8G0845427 reinforcement rail / left, center
(12) 8G0845428 reinforcement rail / right, center
13 N 01412913 fill. hd. bolt, self locking / M5X10
- N 90640201 fillister hd. bolt / M5X12-E
14 8G0845433B gasket / left rear
(14) 8G0845434B gasket / right rear
15 8G0845431 reinforcement rail / left rear
(15) 8G0845432 reinforcement rail / right rear
16 N 01412913 fill. hd. bolt, self locking / M5X10
17 8G0871387 handle
18 N 0133051 spring sleeve / 4X22
19 8G0871401D convertible top lock
19A 8G0871107J spacer plate / 1,0MM
20 N 01470210 allen key head bolt / M6X15
21 8G0871415 collar
22 N 0110524 nut, square / M6
(23) 8G0871443E end plate / left / PR-3FM
F >> 8G-R-001 006
(23) 8G0871443F end plate / left / PR-3FN/3FM
F 8G-R-001 007>>
(23) 8G0871444C end plate / right
25 8G0871445 roller
F >> 8G-P-001 760*
26 8G0871556A gas-filled strut
28 8G0871631B gasket / rear
/ 1980MM
29 8G0871593 retaining strip / rear
30 N 0139575 oval head panel screw / B3,5X9,5
31 8G0871633C gasket / left
for roof frame / front, inner
(31) 8G0871634C gasket / right
32 8G0871645C gasket / left, center
for roof frame
(32) 8G0871646C gasket / right, center
for roof frame
33 8G0871829 adjustment plate / 1,0MM
34 8G0907317B micro switch
35 N 0102631 hexagonal head bolt / M4X6
36 N 0115227 washer / A4,3X9X0,8
37 8G0898241A 1 set of straps with mounting parts
38 8G0871529 foam packing (self-adhesive) / 200X1100X1
/ front
(39) 8G0845421A 1 set of reinforcement for roof frame
40 8G0871597A adjustment wedge / 360X17X1-4
41 8G0871325A limit stop
for roof frame
42 8G0898956 repair kit / left a. right
top frame
43 8G0871289 attachment bolt
F >> 8G-N-002 000* / left a. right
