car never overheats or loses water or oil but the on board sensors say it need water but goes off after a little bit and water is full seems to have a glitch in that way brake sensor is always on
Brake sensor is norm as they have sensors on the pads and if you replace without using Orginal they dont and you cross the wires sometimes that does not work and you get the sensor showing on the dash would not worry about that unless you hear grating when braking
Think thats about it hard cold truth.......I just bought a diesel (50MPG)............ and have the other car for weekends.......use to have 100 2.8 V6 and lucky if i got above 24mpg
