Chris NottVolks Autos
    Oct 2003
    86 5000 engine question
    i am in possession of an 86 5000s with a good engine and an 86 5000 cs turbo with a cracked head. my question is - can i interchange the turbo unit from the cs to the s to give it a little more oomph?
    thanks in advance
    28v6
    Re: 86 5000 engine question
    Negative, The Turbo head has lower compression on the ports to accomodate the Turbo, therefore it will not operate on a standard fuel injected head as it's head has higher compression. Sawwwwwyyy [img]/ubbthreads/images/graemlins/cry.gif[/img] [img]/ubbthreads/images/graemlins/froggie_red.gif[/img] [img]/ubbthreads/images/graemlins/****_you.gif[/img]
    Regards
    Dave M
