Monster MotorsportChris Nott
    Apr 2004
    21
    Unhappy A6 OIL PUMP...PLEASE help!!!
    Hi all,
    Wanted to change the cambelt on my A6 2.5 TDi 5 cylinder so I started the big strip down, lights, bumper, grill, radiator....anyway cut long story short..my oil pump has a crack in it which leaks oil, Audi want 175 + vat, anyone know of a cheaper supplier or a second hand one going any where (already looking Ebay)?
    Even when I get one, the lower cross member and sump then need to come off, I need a second garage to keep all my Audi bits in!!!!!!!
    Greatfull for any help!
    Andy 07762548296
    Rev-head's Avatar
    Oct 2004
    Perthshire
    2,954
    Andy go to www.vagparts.co.uk (call them)a guy martin is very good there and say you were recommended by this site/S2forum and you should get a good price
    That is the only place i can think of new other than that i would try overton scrapyard in Aberdeen..they deliver and strip all bits off for you
    Good Luck
    Urq RR
    S2 Coupe...RS2 +
    S2 Avant (slipper wagon spec)
    A4 AVANT TDI
    enda1's Avatar
    Jan 2006
    Ireland
    439
    If i'm not mistaken Audi supplied this 5 cylinder diesel to volvo and still do. If you need to go to the scrapyards this might give you a bigger selection of newer parts to choose from
    Enda1
    96 S6 2.3T
    99 A6 1.8T SE
    93 80 2.0 (gone)
    93 Kawasaki ZZR600
    Apr 2004
    21
    Smile
    Wow, thanks guys,
    I rang VAGParts today, gave me a price of 140 + vat, then I told him who had recomended him and the price dropped to 129 + vat, Bargain!!!!
    his computer recomended that I would need a new oil sender unit to go with the new pump, I thought that the sender unit was in the side of the block, much higher up than the pump and nothing to do with it really....any thoughts?
    While I'm on...havn't had the A6 long but the computer is reading 34 mpg average, and only got upto 37 mpg on a motorway run, I thought it would be a bit better than that?
    Thanks again for all your help guys, great site, I'll be on here more often!
    Rev-head's Avatar
    Oct 2004
    Perthshire
    2,954
    no problem glad you got sorted out
    Steve
    Urq RR
    S2 Coupe...RS2 +
    A4 AVANT TDI
    Rev-head's Avatar
    Oct 2004
    Perthshire
    2,954
    If he recommended you replaced the sender unit i would do it as he is a clued up fella when it comes to audi's
    Urq RR
    S2 Coupe...RS2 +
    A4 AVANT TDI
