Chris NottMonster Motorsport
    Oct 2006
    high beam/low beam problem
    87' audi quattro 5000cs. When i flick the headlight switch all the way up it automatically goes to high beams. At this point it should be in low beams and when u move the switch that controls low and high foreward it should go to high beams then. When u fiddle with the switch u can see the lights going from high to low, but im just not sure what to fix on it. Anyone else have a similar problem taht could help me out.
    Rev-head's Avatar
    Oct 2004
    Perthshire
    2,954
    Sounds like your indicator/high beam stalk is knackered or is very dirty and needing cleaned i would remove and give it a clean with electrical spray cleaner/carb Cleaner and see if that helps
    Urq RR
    S2 Coupe...RS2 +
    S2 Avant (slipper wagon spec)
    A4 AVANT TDI
