Sky InsuranceEM Tuning
    Sep 2006
    1994 audi 90 wont idel
    i have a 1994 audi 90 quattro cs sport with the 2.8liter v6 engine with the five speed; that ive had for about a week now and as of yesterday it wont idel. when you start it you must apply gas or it will die and when stopping it wont idel it just dies and you have to constantly pump the gas to keep it from dieing, any ideas on what it could be? my initial thought was that there was something wrong with the sensor? but i dont know.
    thanks, aaron
    Rev-head's Avatar
    Oct 2004
    Perthshire
    2,954
    ISV..?.......Idle stabilizer valve is my first thought....... will do a check
    Urq RR
    S2 Coupe...RS2 +
    S2 Avant (slipper wagon spec)
    A4 AVANT TDI
    Rev-head's Avatar
    Oct 2004
    Perthshire
    2,954
    right had a look about to make sure i think you have 2 options
    ISV or O2 sensor
    Picture below is of your engine but probably a bit shiner ..if you look beside the air filter left hand side you will see the ISV the metal item with the hoses coming from it ,you need to take that off and give it a good clean with carb cleaner ,check the wiring ie plug to make sure there is no broken wires and give the plug a good clean and apply electrical grease if at hand
    then get back to us if that works, if not then we go to the next stage
    Urq RR
    S2 Coupe...RS2 +
    A4 AVANT TDI
    Sep 2006
    thanks for the reply, i havent been able to totally clean the ISV out yet due to lack of transportation but i have taken the hoses off and checked the plug; the plug seems to be in good condition as do the hoses i couldnt see any buildup of gunk or anything but ill get back to you on how its doing after i give it a good cleaning.
    thanks, aaron
    P.S. what model number is that air filter, it looks really nice, way better than the original giant black box.
