EM TuningJMB Retrofits
    Aug 2006
    Doncaster
    16
    2.3 E coupe 91 10v- cutting out
    Hi guys
    i seem to have picked up a little problem. you drive along and the next minute the car cuts out. when you start it again every thing is fine. there is a buzzing noise from the fuel tank area. is the fuel pump located in the tank with the fuel sender all in one unit?
    any thoughts on this highly appreciated
    martin
    Rev-head's Avatar
    Oct 2004
    Perthshire
    2,955
    Not sure but pretty certain the Fuel pump is located at the petrol tank..if you look in front of the rear wheel under the sill were the filler cap is you will see it
    My thoughts on this one would be
    Fuel Pump Knackered
    Fuel Pump Relay fault
    Hall sensor fault for timing of crank to Cam and vise versa
    Sure Scotty will come along and shed some light on this
    Urq RR
    S2 Coupe...RS2 +
    S2 Avant (slipper wagon spec)
    A4 AVANT TDI
    Oct 2005
    South Wales
    155
    How often does it cut out? Is it random, only when warmed up, any link to engine speed or throttle position? Does it restart ok straight away?
    Fuel pump relay would be top of my list, but only because I've had one fail myself! Cutting out just gets more and more frequent.
    The fuel pump is in the tank on coupes, but it is underneath on saloon models. They often run for years making a racket, whether you can live with it is another thing.
    May be worth checking for ECU fault codes?
