Monster MotorsportChris Nott
Results 1 to 11 of 11
    May 2004
    6
    Unhappy Audi 80 cabriolet fuel consumption..........
    Hi all,
    a bit of advice needed here :
    l reg cabriolet 2.0, 78K miles new plugs air filter, oil change etc and I am getting 90 (ninety) miles for Ł20.........
    Surely something is amiss here ?
    Any advice or suggestions would be welcome,
    Cheers all,
    Jon (skint)
    Rev-head's Avatar
    Oct 2004
    Perthshire
    2,955
    No that does not sound right would look around air mass flow meter..looks like you have to much of a rich mixture..what colour were the plugs when you replaced them?
    Urq RR
    S2 Coupe...RS2 +
    S2 Avant (slipper wagon spec)
    A4 AVANT TDI
    May 2004
    6
    Thhe plugs were a bit black, but not that bad - mostly brown.....
    I had the emissions checked today - okay apparently.
    Any ideas what the mpg should be for this model ?
    Oct 2005
    South Wales
    155
    Might be worth getting the lambda probe checked.
    May 2004
    6
    Had it checked - apparently okay............
    Looks like a trip to an audi dealership to see whats what.
    Anybody know of a decent non franchised outfit in South Wales ???
    Rev-head's Avatar
    Oct 2004
    Perthshire
    2,955
    How do you drive?
    Urq RR
    S2 Coupe...RS2 +
    A4 AVANT TDI
    May 2004
    6
    Far too sensibly for my own good !
    I don't thrash it, 75 / 80 on motorways, pretty much limits everywhere else !
    Isn't the set up just a heavy 2.0 audi 80 really ??
    Jon.
    Oct 2005
    South Wales
    155
    Only other thing I can think of is the ECU temperature sender, if this is sending duff information, the ECU might think the engine is cold all the time so keeps the cold enrichment (choke) turned on?
    Where are you in South Wales, only indies I know of are Keith Watkins, Llandevenny nr Newport, and there was another one in Tintern nr Chepstow, I forget the name...
    May 2004
    6
    What should the temperature be, approx ?
    It never gets very warm to be honest........possible the previous owner pulled the thermostat ?
    I am in Bridgend btw, suppose Cardiff is my best bet.
    I'll check the yellow pages.
    I just went to Tenby and back - cost me approx Ł32 !!!
    Jon.
    Rev-head's Avatar
    Oct 2004
    Perthshire
    2,955
    Would make a difference if the temp did not go up to normal running temp car should sit at 90 when at normal running temp.....whats it sitting at
    Urq RR
    S2 Coupe...RS2 +
    A4 AVANT TDI
    Oct 2005
    South Wales
    155
    The ECU temp sender is not usually linked to the gauge reading, in other words, the gauge could be reading ok but the ecu temp sender could still be faulty.
    If the thermostat was sticking open, your engine might not be getting hot, so the gauge would stay low AND the ECU would keep throwing extra fuel in..
    I doubt it would run THAT cool in summer, even a British summer!
