Monster MotorsportVolks Autos
Results 1 to 8 of 8
Thread: 12V or 24V
    Jun 2006
    15
    12V or 24V
    Hallo can anyone tell me if the 2.8l V6 1993 Audi 100 engine is 12Valve or 24 Valve . I took off the tappet cover and I only saw one over head cam. but when I went to the agents to get spark plugs and they asked if it were a 24 valve engine
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,676
    If it's a 1993 model, I reckon it's 12-valve. The switch to multi-valve was around 1997, IIRC.
    By the way, the multi-valve is not 24-valve, it's 30, as in 5 valves per cylinder. They're easily identifiable, as the engine cover has "5-Valve" emblazoned across it.
    Hope this helps.
    A4 3.0TDi SE Quattro Auto. Factory-fit: RNS-E/bluetooth; F/R parking sensors; full leather/heated front seats; cruise. Retrofit: Remap; Eibach 30mm lowering springs, RS4 RARB; MTEC drilled/grooved discs; 18" RS4 alloys; VW fan washers; Kinetic Digitizor DAB; Blackvue DR380 camera; front armrest; ambient lighting; white LED lights; autodim mirror; Cupra splitter; S-Line door blades; tints; UK pressed plates; MFSW; SDS; TPMS; LED Taillights and DRLs. RS aluminium pedals
    Jun 2006
    15
    thanks but I read a book that stated the enginr was DOCH (double over head cam).
    corne
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,676
    It may well be DOHC, but your question was how many valves it has, and like I said, unless it's got a badge saying 5-valves (per cylinder), then it's a 12-valver.
    Jun 2006
    15
    then there must've been a difference between our engines and your countrie
    's. After our chat I went to the garage, they stated that our engines (AAH)
    was 24v with Doch
    Corne
    icenutter's Avatar
    Jun 2006
    595
    According to this webpage aah is a 2valve engine (ie 12valve in total)
    bentleypublishers.com
    icenutter's Avatar
    Jun 2006
    595
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,676
    That confirms what I said, that Corne's engine is a 12-valver.
